DTC PO603
Old Feb 11, 2021 | 03:57 PM
Arizona97's Avatar
Arizona97
DTC PO603
I pulled codes today, got a DTC PO603 from PCM, KAM keep alive memory? or battery connections or bad PCM.. Can anyone enlighten me on this code?
Many thanks to all that respond
Old Feb 11, 2021 | 05:17 PM
Wes444's Avatar
Wes444
Usually that's a code that pops up when you disconnect the batteries. Takes a while to clear.
If you haven't messed with your batteries it also come up when you lose power to pcm, like unplugging it to add a chip, but even then you should have unhooked the batteries first.
And in my case, it happened when my fuel bowl heater went bad, so I also run it unplugged for the past 3 years or more
Old Feb 12, 2021 | 02:13 PM
Arizona97's Avatar
Arizona97
PO603
Thanks, I am felling better already.
Ed
wildstang
Jun 26, 2017 06:09 PM
ZombiePopper
Feb 26, 2015 06:37 PM
cps
Apr 13, 2008 04:30 PM
Blurry94
Apr 21, 2004 11:43 AM
beaboarder
Feb 11, 2004 06:08 PM
