Deciphering trouble code
Old Nov 7, 2003 | 05:26 PM
beaboarder's Avatar
beaboarder
Does anybody know what the diagnostic code PO603 , and P1211.I know the interpretations but what could cause these codes.
Thanks.
Old Nov 7, 2003 | 06:03 PM
Larry Heath's Avatar
Larry Heath
P0603 is " Internal Ctrl Mod KAM Error" I get that one after reprograming my computer, it dosen't seem to mean anything in my case. The check engine light comes on during a reprogram, I erase it after programing and the truck runs fine.
P1211 is "IPC not controlable- Pres Above/Desired" Something to do with A/F metering, just what this means is a good question.
Later Larry
Old Feb 10, 2004 | 09:55 PM
g8rh8r's Avatar
g8rh8r
I've programmed and reprogrammed my PSD with the microtuner, and tonight was the first time I ever got the P0603 code, or any other for that matter. I hope Larry is right, but I'm wondering why it has come up.
Old Feb 10, 2004 | 10:18 PM
g8rh8r's Avatar
g8rh8r
Beaboarder,
I just went through about 30 websites, and I finally came to one that may help. I know it's been a few month's since you posted this, but figured if you didn't have the info, here it is.
P0603 -Powertrain Control Module KAM Test Error
Indicates the PCM has experienced an internal memory fault. However there are external items that can cause this DTC.
-Reprogramming
-Battery terminal corrosion
-KAPWR to PCM interrupt/open
-Loose battery connection
-Damaged PCM
If KAPWR is interrupted to the PCM because of a battery or PCM
disconnect, DTC can be generated on the first power-up.
Old Feb 11, 2004 | 06:08 PM
JC 6.0's Avatar
JC 6.0
Using a chip or aftermarket programmer also sets code P0603! It also makes diagnosing other problems very difficult. Due to the other codes being erased and all that is in there is P0603!
