Factory Idle up????
Feb 10, 2021 | 06:24 PM
Quote:
Originally Posted by
mattymax
I got the switch because there are sometimes I want it to be activated and it doesn’t.
x3, I installed the BD kit so I can control it and also make it idle higher than 900-1,000 if need be.
Feb 11, 2021 | 03:30 PM
nick112288
So then no, it doesn't come with it from the factory.
Chevy and Ram both integrate it into the cruise control buttons, no need to wire anything in.
Right and it can be adjusted based on desired needs
Feb 12, 2021 | 07:08 AM
I have a 2019 Gas F450. Is there a way to hook up one of the uupfitter switches to a high Idle resistor, or do I have to buy a kit..??
I have a pto and I would like to idle the engine up when in use.
Gordon
Feb 12, 2021 | 11:52 AM
Just out of curiosity about how long does it take for the 6.7 to start blowing warm air?
My 12 valve takes forever, even plugged in. Part of my deciding factor on which truck to go with is how quickly I'll be warm in the cold mornings!
Feb 12, 2021 | 01:54 PM
nick112288
Depends...Auto climate control starts blowing warm once coolant is ~130°F...just got to get in and start driving...
Feb 12, 2021 | 01:57 PM
nick112288
If it's been plugged in, pretty quick. Although remote start with a 1200 rpm resistor for 5 to 10 minutes doesn't hurt.
Feb 12, 2021 | 01:59 PM
I start getting heat at about 100 degrees.
With it plugged in and no auto start the temp shows about 70
Feb 12, 2021 | 08:19 PM
nick112288
I can feel some warmth in just a few minutes in mine. But I do have the supplemental heater.
ncsuperduty
Jan 11, 2018 01:00 PM
05F250DSL
Nov 12, 2014 05:03 PM
Brian460
Dec 8, 2009 12:27 PM
tpolley
Oct 16, 2008 08:26 PM
sourbeer
Dec 24, 2007 09:09 AM
