6.7 dies while towing
Old Feb 9, 2021 | 06:55 PM
JackLEd's Avatar
JackLEd
2018 6.7 gives a reduced engine speed while towing up hill with max boost. Engine just shuts down. No codes or check engine lights. Cranks right back up and goes again. Any ideas? New to forum.
Thanks
Old Feb 9, 2021 | 07:00 PM
Just Strokin's Avatar
Just Strokin
Did you recently replace fuel filters? Or add an aftermarket item to the fuel system?
Old Feb 9, 2021 | 07:04 PM
JackLEd's Avatar
JackLEd
All stock, fuel filters changed every 30k oem filters. Doesn’t shut down if I feather throttle up the hills.
Old Feb 9, 2021 | 07:36 PM
senix's Avatar
senix
EGT's?
What about codes or check engine light or the wrench indicating a power train fault?
Old Feb 9, 2021 | 07:55 PM
JackLEd's Avatar
JackLEd
No wrench or engine lights. No codes.
Old Feb 9, 2021 | 10:06 PM
HRTKD's Avatar
HRTKD
I doubt the problem is the fuel filters, but if you're towing, the fuel filter change interval isn't 30K, it's 15K.
How much are you towing? Pickup or chassis cab? What are the engine oil and coolant temperatures just before it shuts down?
Old Feb 10, 2021 | 05:44 AM
JackLEd's Avatar
JackLEd
18’ utility trailer with 2k lbs. nothing major. Oil temps around 205 and trans around 200.
Old Feb 10, 2021 | 05:45 AM
JackLEd's Avatar
JackLEd
Crew cab 4wd short bed
Old Feb 10, 2021 | 09:12 AM
HRTKD's Avatar
HRTKD
Can you reproduce the event?
Old Feb 10, 2021 | 09:23 AM
JackLEd's Avatar
JackLEd
Yes, put some weight behind it and run 80mph up a hill.
the more weight, the quicker it shuts down.
Old Feb 10, 2021 | 09:44 AM
HRTKD's Avatar
HRTKD
Get a service tech in the passenger seat and get them to connect to the system when you reproduce the problem. Otherwise, they'll never reproduce it themselves.
Old Feb 10, 2021 | 01:09 PM
kper05's Avatar
kper05
I'm really interested to know the outcome of this since temps are very reasonable but seems temp related (more weight, more heat = faster shutdown). What does the analog temp gauge show prior to shutdown? Bad sensor somewhere is my guess. Does your dash report soot percentage?
Old Feb 10, 2021 | 02:12 PM
senix's Avatar
senix
they are going to have to hook up a data recorder.
Old Feb 10, 2021 | 05:06 PM
speakerfritz's Avatar
speakerfritz
what type of code reader are you using?
sounds like an egt#3 problem to me
use forscan to review cold egt temps
compare the #3 egt to see if it is hundreds off from the others when cold.
Old Mar 2, 2021 | 10:03 AM
JackLEd's Avatar
JackLEd
Hooked up a reader and replicated shut off. Got a P0093, large fuel leak. No fuel leak existed. Once truck restarted, truck cleared code on its own. Replaced fuel regulator on the end of the rail. Will follow up after a few days of running.
