6.7 dies while towing
Old Mar 13, 2024 | 12:42 PM
  #46
kayakingpoodle's Avatar
kayakingpoodle
Originally Posted by CJFL
I have had this truck to 2 separate Ford Dealers, both of which cannot find a code stored on the computer. I'm not sure if the code is somehow clearing itself, but 2 separate "Master" diesel techs seem to be baffled at what I am experiencing. These are older gentlemen who look like they have been doing it for a while.
I read on another forum that replacing the driver's side fuel rail might solve my problem, but no reason was given as to why. I looked this part up , and it looks like an OEM replacement is less than $200. https://www.getoemparts.com/oem-part...EaApiPEALw_wcB
Do you think replacing the fuel rail is worth a shot? What would go wrong on a fuel rail, and why the driver's side specifically?
I did have the fuel filter changed right before this problem started happening. Do you think swapping a fuel filter again would be a good course of action?
It can be either or both rails, the driver side is more common because it has an extra orifice or to for balancing fuel between the banks, the passenger rail has them too just not as many. I am not sure if there is a way to diagnose them other than to replace and see if the issues clear up. If there is a way to diagnose them I would like to know how.
Old Mar 13, 2024 | 12:49 PM
  #47
Overkill2's Avatar
Overkill2
If that's the case, and you're talking balancing between the two rails, wouldn't that be pressure and wouldn't that throw a code?
Old Mar 13, 2024 | 12:53 PM
  #48
kayakingpoodle
One would think, but from what I have read/seen and discussed, the rails can cause a variety of intermittent and constant weirdness.
Old Mar 13, 2024 | 12:57 PM
  #49
Overkill2's Avatar
Overkill2
I'm thinking I remember a recent thread where a truck had issues and it turned out to be the driver's side fuel rail. And I believe he didn't replace it after having a CP4 go out if anyone else remembers that.
Old Mar 13, 2024 | 01:01 PM
  #50
kayakingpoodle
Maybe this one New member w/ a truck gremlin ?
Old Jun 24, 2025 | 08:50 PM
  #51
JLW9971's Avatar
JLW9971
1st Gear
Spoiler
fyermn
2015 - 2020 F150
Jul 4, 2021 06:46 AM
j759ll
Sep 7, 2017 07:08 AM
landscapeguy
Jun 14, 2014 08:30 PM
MooseMan2
Oct 16, 2012 07:03 PM
buffchick
All Things Towing
May 29, 2006 05:18 PM
