6.7 dies while towing
Old Aug 14, 2023 | 05:42 AM
  #31
The Bone's Avatar
The Bone
Having a tuner complicates things. You don't know what is happening without data logging.. Tunes have been the cause of all sorts of issues. I would dump the tune and see what happens. It may be interference with the computer in the truck.
Old Aug 14, 2023 | 08:14 AM
  #32
StanleyZ's Avatar
StanleyZ
I would return to stock and still may if I have to. I can’t blame the tune for the over boost because the tune was on for a couple years before it started. But, I get I could blame it for preventing the codes that would tell me what is happening. Putting that POS back on at my age (80) is a lot if work. I keep trying to find an easier solution or a tech that can figure it out without codes.
Old Aug 14, 2023 | 08:48 AM
  #33
Overkill2's Avatar
Overkill2
That's crazy you can't get to the bottom of this Stanley... wishing you luck with solving this...
Old Aug 14, 2023 | 10:01 AM
  #34
speakerfritz's Avatar
speakerfritz
It clear to me if this a chug-alug-chug-kaput kind of shut down or if the engine just instantly powers off.
the former being fuel and the later being electrical.
Old Sep 29, 2023 | 08:34 PM
  #35
T Houston's Avatar
T Houston
2nd Gear
Same issue with me. 2018 F250 Lariat Super Duty
Did you find the solution for the issue with towing because I’m having the same thing going while hauling my fifth wheel trailer
Old Dec 21, 2023 | 10:40 PM
  #36
jmoor808's Avatar
jmoor808
4th Gear
hey I’m having the same problem did you fix yours?
Old Dec 21, 2023 | 10:42 PM
  #37
jmoor808's Avatar
jmoor808
4th Gear
Originally Posted by JackLEd
All stock, fuel filters changed every 30k oem filters. Doesn’t shut down if I feather throttle up the hills.
I’m having the same issue did you get it fixed?
Old Dec 21, 2023 | 11:54 PM
  #38
James Hodge's Avatar
James Hodge
4th Gear
Anyone check your m.a.p. sensor for being clogged also m.a.f. sensor being dirty?
Old Dec 22, 2023 | 08:35 AM
  #39
jmoor808's Avatar
jmoor808
4th Gear
My 6.7 power stroke shut off when I’m putting a load, but will crank right back up. I’ve changed the high-pressure fuel pump, low pressure, fuel pump and fuel regulator. Truck drive fine unless I’m pulling a load going uphill. As long as I stay under 20 PSI going up here with the load, the truck will keep running if I go over 20 PSI for a while the truck was shut off truck been deleted and tune. I have fass ride low pressure fuel pump installed also. H&S tuner. Only code I have is p007D charge air cooler sensor circuit high
Old Dec 22, 2023 | 02:28 PM
  #40
Overkill2's Avatar
Overkill2
The only thing I could think of is the AIT sensor is causing that code...
Air Intake / Charge Temperature Sensor
Old Mar 12, 2024 | 05:02 PM
  #41
CJFL's Avatar
CJFL
2nd Gear
I have this exact same problem. Just trying to get this figured out so i don't have to trade my truck in.
Did anyone figure out how to solve this?
  • I have a 2017 F250 with the 6.7
  • When towing only, and when going up hill, the transmission will downshift to maintain vehicle speed
  • Engine oil 212F, Trans oil 208F, Boost over 20 pounds
  • Engine gives "reduced power" warning, but engine immediately shuts off
  • No codes or check engine lights on my display
  • Engine starts right back up and truck drives normally afterwards
  • This only happens when the engine downshifts, has a heavy load behind the truck, and the truck is trying to maintain speed
  • Not a fun experience when towing on the highway
  • I noticed if I drive slower (60 mph vs 65 mph), I won't get the event
Any feedback on solutions would be much appreciated.
Old Mar 12, 2024 | 05:23 PM
  #42
HRTKD's Avatar
HRTKD
There may be stored codes that aren't causing a check engine light.
Old Mar 12, 2024 | 05:39 PM
  #43
CJFL's Avatar
CJFL
2nd Gear
I have had this truck to 2 separate Ford Dealers, both of which cannot find a code stored on the computer. I'm not sure if the code is somehow clearing itself, but 2 separate "Master" diesel techs seem to be baffled at what I am experiencing. These are older gentlemen who look like they have been doing it for a while.
I read on another forum that replacing the driver's side fuel rail might solve my problem, but no reason was given as to why. I looked this part up , and it looks like an OEM replacement is less than $200. https://www.getoemparts.com/oem-part...EaApiPEALw_wcB
Do you think replacing the fuel rail is worth a shot? What would go wrong on a fuel rail, and why the driver's side specifically?
I did have the fuel filter changed right before this problem started happening. Do you think swapping a fuel filter again would be a good course of action?
Old Mar 12, 2024 | 05:51 PM
  #44
HRTKD's Avatar
HRTKD
Check to make sure the fuel filter and fuel filter lid (on the lower fuel filter, by the fuel tank) are properly seated. Supposedly air can be introduced when they are not seated. That's about all I remember about that situation.
Old Mar 13, 2024 | 10:37 AM
  #45
Overkill2's Avatar
Overkill2
There's no doubt if the lid and seal on the lower filter on the newer trucks, just like cap on the lower filter/pump unit of the 11 to 16s is not tightened all the way to those stops so they meet, air will be introduced into the system.
Another thing to consider are the factory quick connect fittings, make sure there isn't an O-ring that folded over and is not making a proper seal with the male fitting of the fuel line. I remember reading that somewhere also...
The fact that it was acting fine until the filters were changed says that it has to do with that. Factory Motorcraft filters?
