Hum/vibration when turning
Old Jan 28, 2021 | 08:18 AM
gg1968's Avatar
gg1968
I just replaced my 97 F250 4x4 front inner/outer wheel bearings. I’m getting a hum/vibration when turning right. It is worse on an “inclined” turn. If I swerve left to right, I can hear it as well. The original bearings looked ok, but swapped them anyways. Problem still persists.
Old Jan 28, 2021 | 09:39 AM
jas88's Avatar
jas88
So you were having this noise before replacing the bearings? Did you also replace the races?
Old Jan 28, 2021 | 10:04 AM
gg1968's Avatar
gg1968
I (embarrassingly) admit that I didn’t replace the races. The ones in there looked totally smooth and fine. I could be the races that are bad, even though they are perfectly smooth?
Old Jan 28, 2021 | 10:09 AM
SFaulken's Avatar
SFaulken
Lots of guys do it, but I don't. Always replace the cups and cones as a set. It's entirely possible that I'm all wet, but if the cones are worn out, the cups have usually "mated" themselves to the bearing pattern of the worn cones, and putting new cones on used cups usually A) Is going to howl and grind like a big dog, and B) is going to wear out your new bearing cones much faster, and possibly just wipe out the cups. Just not something that I take a chance on to save a few bucks.
Old Jan 28, 2021 | 11:47 AM
Conanski's Avatar
Conanski
Sounds like a bearing problem but just to rule it out.. the front hubs aren't locked in are they?
Old Jan 28, 2021 | 03:41 PM
gg1968's Avatar
gg1968
Hubs are NOT locked. I guess if the hubs are free to move and in 2WD mode, it can’t possibly be the spindle bearings?
Old Jan 28, 2021 | 03:50 PM
jas88's Avatar
jas88
You should turn your half shafts and your driveshaft by hand to make sure your hubs are not locked via a mechanical failure internally, even tho they are not "visually" locked.
You gotta replace the races and the bearings together, IMO.
Old Jan 29, 2021 | 07:12 AM
gg1968's Avatar
gg1968
I did spin the shafts by hand. Definitely not locked up. Yesterday I took my truck for a drive and the sound is gone. WTF. I can’t explain it.
jeff69z28
Jul 17, 2020 03:59 AM
HunterSThompson
Feb 19, 2020 10:20 PM
79FordBlake
Jan 2, 2012 08:34 PM
pmasley
Nov 10, 2010 09:42 PM
dyna
Oct 7, 2009 09:53 AM
