Vibration when decelerating
Old Oct 6, 2009 | 09:31 AM
dyna's Avatar
dyna
I started getting a vibration when I decelerate.I notice it mainly in the floor board,seat and steering wheel. When I accelerate,it stops. I checked the u-joints,they are ok. The truck is an '02 with warn locking hubs,which are in the free position. Could it be a tire problem? I don't get any clunking when I put the trans in reverse,and get no noise or vibration when accelerating. As soon as I take my foot off the pedal,it starts.
Old Oct 6, 2009 | 09:53 AM
pbr man's Avatar
pbr man
How did you check your u-joints? When I changed mine out they were tight when I grabbed ahold of them, but when I took them out they were rusted and the needle bearings were shot.
Old Oct 6, 2009 | 10:05 AM
4inchlovin's Avatar
4inchlovin
have you tried throwing it in neutral and coasting to see if it does it.
Old Oct 7, 2009 | 08:16 AM
dyna's Avatar
dyna
Yes.I did put it in neutral and I still had the same amount of vibration. I'm also getting a squeeking noise coming from the front right wheel. Could this be related?
Old Oct 7, 2009 | 08:30 AM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
Due to where the noise is coming from and where the location of the tranny is, I would make a guess at torque converter.
Diane
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old Oct 7, 2009 | 09:53 AM
4inchlovin's Avatar
4inchlovin
Im going to say wheel bearing... Jack up the front of your truck, put a pry bar in your rim and see if it has up and down play. If so have a friend move it up and down for you and look behind the wheel and see if the play is at the wheel hub assembly.
mattm04
Apr 14, 2017 07:04 PM
mushman
Sep 29, 2016 05:16 PM
eberlestock
Sep 5, 2016 11:48 AM
CheckYosef
Jul 27, 2016 09:50 PM
1990-f250
Dec 3, 2015 04:52 PM
