Sponsored by: Auxito
Transmission Problems
Old Jan 27, 2021 | 09:35 PM
Art Hendrickson's Avatar
Art Hendrickson
Can an MLPS switch cause a Transmission from going into reverse mode if it's bad? Recently took a 4.6 from a 97 F-150 2 wheel drive motor and put it in a 2000 F-150 4x4 and got a wore harness for it and hooked everything back up to the stock requirements. The original motor that was in this truck had a broken intake valve on the #8 cylinder and dropped valve through the top of the piston causing us to do an engine swap. The transmission was working fine for 2 days and then went to put it into reverse and there wasn't one. Now we put it into reverse and it wants to still go forward is there something wrong with the transmission or is it a computer issue? The Transmission is a 4R70W stock transmission for this truck.
Old Jan 27, 2021 | 10:15 PM
ford390gashog's Avatar
ford390gashog
No it's a transmission issue.
Old Jan 27, 2021 | 10:55 PM
Lime1GT's Avatar
Lime1GT
Just throwing some thoughts out there. Reverse band servo piston o-ring. Low/reverse band and reverse clutch are applied in reverse. Low/reverse band also applied in Manual 1st.
Old Jan 28, 2021 | 08:46 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
No, it cannot. NOTHING electrical can cause no reverse. That has to be a mechanical problem in the transmission.
dangerranger10
1983 - 2012 Ranger & B-Series
Oct 29, 2010 01:23 AM
charles.bunch
Mar 11, 2010 10:28 AM
bassmaster747
1997 - 2003 F150
19
Mar 4, 2008 02:43 PM
blarney
Jul 17, 2007 01:20 PM
