Sponsored by: Auxito
No Reverse
Old Feb 17, 2008 | 07:29 PM
bassmaster747's Avatar
bassmaster747
97' f-150 wont go in reverse
I have a 97' F-150 and whenever i put in in reverse all it dose is rev up
but when the motor is cold it goes in reverse like its brand new
please help me and give me any tips u might have thanks
Old Feb 18, 2008 | 07:06 AM
projectSHO89's Avatar
projectSHO89
You're going to need to open the transmission. Something is bleeding off hydraulic pressure in the REV circuit when the fluid warms up and thins out. That usually means a failed internal seal, valve, frictions, or piston.
Probably rebuild time.
Steve
Old Feb 19, 2008 | 09:40 AM
MrBSS's Avatar
MrBSS
I agree with Steve.
Old Feb 19, 2008 | 04:17 PM
bassmaster747
thanks
how much do you think that would be $$
Old Feb 19, 2008 | 04:57 PM
96f150's Avatar
96f150
Check your fluid level in the transmission
Old Feb 20, 2008 | 09:58 PM
tampa898's Avatar
tampa898
Might be just a plugged filture, start with the easy stuff first.
Old Feb 20, 2008 | 10:08 PM
JoBoOtSdEfAyGo's Avatar
JoBoOtSdEfAyGo
I own a '97 F-150 as well. I had the same problem in my transmission except it happened whenever I put the gear into DRIVE. However, my transmission fluid was quite low and needed to be changed. So I changed it, making sure it got to the proper level and that fixed the problem.
Old Feb 29, 2008 | 10:48 AM
bassmaster747
how much do u think that would cost
would it be better to just get a new trany
Old Feb 29, 2008 | 10:51 AM
couleeman's Avatar
couleeman
Change the filter and fluid first. A few $ in fluid is cheap if it give you another 2-3 years out of the tranny.
Old Feb 29, 2008 | 11:00 AM
nhill2090's Avatar
nhill2090
generally once you lose reverse, your tranny is ready for a new life
Old Feb 29, 2008 | 12:35 PM
projectSHO89
Exactly. Anyone who suggests otherwise is relying on either prayer or wishful thinking.
Steve
Old Feb 29, 2008 | 08:02 PM
monckywrench's Avatar
monckywrench
Lucas tranny spooge can help get more miles out of a trans with tired seals. I fill 1/2 way with fresh fluid, start the vehicel, then dump in the Lucas so it mixes. Top off as needed.
Given that a remanned trans costs the same either way, I'd run the aging unit until it really started to tear up.or at least until I had the replacement in hand.
Old Feb 29, 2008 | 10:19 PM
nhill2090's Avatar
nhill2090
Lucas additives, read up
http://www.bobistheoilguy.com/images/lucas/lucas.htm
interesting stuff there
Old Mar 1, 2008 | 10:01 AM
oddballish's Avatar
oddballish
You might verify that the linage is actually fully engaging, could be the valve is not fully engaging. Don’t know if that would be effected by the warm vs. cold ??.Just some thing simple and cheep to check.
Old Mar 1, 2008 | 07:06 PM
monckywrench
"Lucas additives, read up
interesting stuff there"
I'm not advocating them in oil, but have used them with known dying automatic transmissions and bought some time that way. The transmissions shifted quicker and performed dramatically better. There was no "placebo effect". In all cases I assumed dying pump and/or weak internal seals.
I haven't tried brake fluid to swell seals, since I don't have a junker handy at the moment, but have heard of that as a temp remedy for dying trannys too. Like running STP or gear oil in a dying engine, this isn't presumed to "fix" the problem for good.
