Installed S&B 60 gal tank in my 2020 F350
I completed my installation yesterday of S&B 60 gallon tank.... I have yet to reprogram it for the new size... or fill the tank yet.
I had no issues with the fit or finish of the tank.
However, I did have to lower the tank back down a bit to free the front vent line. I got it pinched and plugged between a frame member and I am glad I caught it, else the tank will not fill properly. So if you are doing this install, be very aware of getting this hose out of the way before seating the tank.
My most difficult part was getting the factory fill and vent hoses off and then back on again.
I can recommend this tank, for those that are thinking of getting a larger tank.
25.2 MPG - just how slow do you drive?
Yes, that's correct.
https://www.sbfilters.com/fuel-tanks...nk-powerstroke
The following users liked this post:
Thanks Squirrel. I had to drop the tank in my Excursion (did it myself) to swap the hitch, so just seeing if there was anything additional to this swap. Although the Excursion tank is much more compact (cubical) rather than elongated, so it may be a bit more awkward to get it lifted in place.
