TRIAX Impressions
#106
You wanna step outside? I'll show you what those pinecones are for...
Ok seriously, my wife collects them from our various camping destinations, and puts them on the wall there. I prefer to collect 7.3 parts pulled off the rig and put them on the wall.
Darn it, Wes, you called it right. Handling a buc...ahem pail of oil is not a big deal. I'm glad you suggested it.
#107
#108
Come on... Let's not get scientific and fancy using "technical" terminology from the interwebs, that is just nonsense.
Pail it is and thank you for tracking that down.
I will probably go with the 4x one gallon jugs though as I am not 100% sold in the Triax yet. I am still considering TSC 15w40, Schaeffer's OTR, Rotella T6 5w40, etc going forward and long term use. The words from jstihl are encouraging and I look forward to what Jeff has to say. I would prefer not to have a "pail" to dispose of with an exiled gallon left over if I can help it. I have enough crap on the floor of my garage already waiting for the truck to arrive and go under the knife.
Jeff, many people will be looking for your "impressions" and thank you for not starting another oil thread. emoji...emoji...
#110
This for sure. They make a great trash bucket in the bed of the truck. Let's see....used oil container for taking in, storage of spare parts, wash bucket, and so many other uses.
#111
As long as you pour a gallon off the top first...or 5 quarts if using the stock size filter and don’t touch the HPOP, it’s probably not that big of a deal since you already know you’re pouring it all in and don’t have to let up. Plus it’s when a container is full-full is when it’s most likely to make a mess tipping it over.
I’d probably use the loose quart to prefill the oil filter because why not.
#112
Although, I already have a short stack of buckets/pails that I use for hauling/mixing concrete, mortar, rocks, dirt, etc... I store empty gallon jugs in the shed in order to fill them and take them into the parts stores for oil recycling. Then just replenish the stock with the jugs I just emptied. For my weak and lazy ***, it is just easier to lug a few gallons into the store than a large pail (proper scientific terminology utilized). One of the parts stores requires the oil be poured into the large container and the opening is about eye level and 8" in diameter, so pouring a 5 gallon pail of used oil can get messy. Ask me how I know...
I don't use my repurposed pails/buckets to store trash or anything, I put trash in the trash cans at fuel stops, my garage or another appropriate place for trash.
To each their own though and I commend you for your recycling/repurposing efforts.
#113
#114
Tried to grow a pair, but didn't quite get there. I cheated and poured a gallon off the top of the 5 gal bucket to a 1 gallon container using the tailgate method, then put a moving blanket on the engine and filled the crankcase with the remaining 4 gallons. I left the oil filter empty, and sucked the HPOP reservoir dry for this change. I keep forgetting oil is not as heavy as water. The pail was not that heavy - I thought it worked well and was very controllable.
As you'd expect, it took a couple of 15 second cranks to get it to fire up, but it also gave me a chance to listen to the starter and see how strong the batteries were.
I'll drive it hard to get the rest of the air out of the oil system before I take another sound reading. I haven't noticed a big change in idle noise yet.
#115
#116
#117
I expected some heated debate in an oil thread but figured it would be about the oil or additives or such. Never expected folks to have such strong feelings on the containers it comes in.
BTW I could use a couple more 5 gallon “pails” for my used oil containment. Believe it or not I lost one of mine to rust last year.
#118
Now I have a "pail potty" illustration I can use (thanks beachcamperf250!).
Brandon - good to know on the HPO circulation. I've got some driving to do.
I did like pouring the oil in all at once - just rotated the pail to lower the spout until she was mostly empty, then tipped up the last of it. I'll keep the HPOP reservoir full next time, and pour off 5 quarts ( I have a 5 quart clean oil container). I guess I'll keep the current 5 gal pail with 1 gal of Triax around as a collection point for the pour off from the next few oil changes.
#119
(Sarcasm on)
At least the "pail potty" idea combined with the left over oil residue would provide exceptional lubricity properties for removal of the "crap and/or crap bag". This surely is due to additives like Boron, ZDDP etc...
The real question is... What does a decibel meter read regarding Triax pail vs. Home Depot bucket while it is in use as a "pail potty".
(/sarcasm off)
(/sarcasm off)
