Key switch problems
Old Jan 7, 2021 | 02:11 PM
ddouylliez's Avatar
ddouylliez
Key switch problems
So I've been having a problem with my key switch. I can start the truck and it runs pretty good other than while I'm driving all power to the truck will just stop other than tail lights and head lights. When i start the truck it will run but I have to move the key back from the start position and the power to everything in the truck will work. if I turn the key switch back just a hair it will completely die again. I have changed key switch cylinder as well as the solenoid the key switch goes to.. Any idea on what i may have overlooked?
1990 F-150 XLT Lariat with a 351W
Old Jan 7, 2021 | 02:24 PM
sandymane's Avatar
sandymane
Hello. You need to give us the model, year, motor and any other helpful information. Sandy
HE EDITED HIS POST TO INCLUDE THE INFO FOR ANYONE THAT CAN HELP HIM>
Old Jan 8, 2021 | 08:05 AM
tjc transport's Avatar
tjc transport
i ain't rite
sounds to me like the ignition switch on the column under the dash is failing.
common problem with these older trucks. the ignition switch is a two part unit. half plastic, half aluminum. over time they plastic gets brittle and the two pieces separate.
i have replaced will over 100 ignition switches in these trucks over the past 30 years.
Old Jan 8, 2021 | 11:57 AM
My4Fordtrucks's Avatar
My4Fordtrucks
You replaced the ignition lock cylinder but what are you referring to as the “solenoid the key switch goes to?” Are you taking about the solenoid on the passenger fender? If you replaced the ignition switch on the lower column then perhaps you don’t have it probably adjusted.
Old Jan 13, 2021 | 06:44 AM
ddouylliez's Avatar
ddouylliez
Yeah, I was referring to the solenoid on the passenger fender. I don't think that is my issue though. I took a good bit of the column apart yesterday evening and I pretty much made the problem worse unfortunately. I removed the key switch cylinder and turn signal switch to make sure anything wasn't out of place. In the process of reassembling, the turn signal switch started working again. (I replaced the turn signal switch twice and it failed again like a month ago). After I completely reassembled, turn signals stopped working again. I'm pretty sure it has to do with my initial key switch problem. So now the key switch cylinder is really hard to turn and the key won't turn back far back enough for me to be able to take the key out unless I remove the whole cylinder. truck won't stay running unless I hold the key almost in the (turnover) position after it's running
Old Jan 13, 2021 | 08:13 AM
My4Fordtrucks
There is no “key switch cylinder”. At least in my mind it is confusing what part you are talking about. There is a lock cylinder and ignition switch: two separate parts. It sounds like you disassembled the column enough to have the actuator out of time. That could explain why you cannot turn the key backwards enough. I assume the “turnover” position is START? Did you try adjusting the switch before you torn down the column?
Old Jan 13, 2021 | 09:17 AM
ddouylliez's Avatar
ddouylliez
My bad, it's the lock cylinder that won't turn back all the way to remove the key. I was just looking to see if anything was broken or out of place when I was disassembling. I'll have to look into how to adjust the switch. This small issue has me so frustrated but it comes with all vehicle projects lol
Old Jan 13, 2021 | 10:17 AM
My4Fordtrucks
Can’t find the “How to” on the actuator install and adjustment but here is a thread with a link to a Bronco forum: https://www.ford-trucks.com/forums/1...-question.html
The switch has slots. Loosen the two nuts to allow it to slide.
Old Jan 13, 2021 | 11:08 AM
tjc transport
i ain't rite
here are instructions on actuator replacement:
https://www.ford-trucks.com/forums/8...ml#post7764350
NICKSAN
Aug 31, 2020 09:53 PM
oliver28472
Apr 24, 2013 05:18 PM
NewEnglander
1978 - 1996 Big Bronco
17
Apr 16, 2012 11:46 PM
66F100Again
Dec 9, 2006 05:41 PM
flatgreen55f100
Feb 28, 2005 02:03 PM
