Running board/step compatability
Old Jan 3, 2021 | 09:23 PM
JT250's Avatar
JT250
Will 2020 steps fit on our trucks? Found some 2020 take offs.
Old Jan 3, 2021 | 09:30 PM
Colorado350's Avatar
Colorado350
I’m guessing the mounting brackets are significantly different. Anything can be fabricated if you have the capability.
Old Jan 3, 2021 | 10:08 PM
JT250's Avatar
JT250
There are 2 different sets for sale on marketplace. One says 2017-2020 so I guess those are the same? Curious if anyone has tried. I guess I'll look at my mounting brackets.
Old Jan 3, 2021 | 10:16 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Best thing you can do is find a set of the same year you are looking at buying and compare the mounting locations to your cab. You should be able to get a rough measurement from the front of the new boards to the first mounting bracket and check that against your truck.
Another option is go to a dealer lot with a tape measure and cell phone for pictures and measurements to compare to your truck.
I installed a set if Iron Cross wheel to wheel bars that I got for a steel of a deal. I use them a lot and would not be without them now. Let us know what you find out sir and good luck to you.
Old Jan 3, 2021 | 11:22 PM
milehi_350's Avatar
milehi_350
They will not fit at all. The bracket is significantly different. I looked at putting a pair from a ‘19 on my ‘01. They’re not close. They changed after ‘16.
Old Jan 4, 2021 | 08:04 AM
JT250's Avatar
JT250
Thanks! I figured someone had tried already.
Old Jan 4, 2021 | 09:35 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Yep. Up through 2016 you're good because Ford had the wherewithal to use the same cab floorpan layout from 1999. You don't go bankrupt when you leave stuff alone and don't change it every model year.
sealer700
Sep 16, 2019 10:48 PM
seminaryranger
Aug 14, 2009 10:19 PM
xmaicorider
1997 - 2003 F150
May 27, 2008 04:20 PM
75 SuperCab
Oct 6, 2006 01:08 AM
