Sponsored by: Auxito
Running Board mounting - HELP!!
Old May 25, 2008 | 09:25 PM
xmaicorider's Avatar
xmaicorider
Ok - I may have made a mistake - but I bought a set of factory Ford running boards for my 97 F150 at a swap meet - not knowing what I was doing I assumed that it had the correct brackets on it - of course the guy selling them assured me that they would fit a 97 F150 - it has the flat brackets that from what I can see on newer ones bolts right to the underside of the cab - problem is that my truck has an inch lip along the bottom of the cab so the flat brackets wont work - does anyone have or know where I can get picture/diagram of what it is supposed to look like or know where I can buy the correct brackets - any help would be appreciated. Thanks
Old May 26, 2008 | 07:51 PM
Lavern's Avatar
Lavern
what kind of running boards are they?
Old May 26, 2008 | 09:56 PM
xmaicorider
the best way I can describe them is they look just like the running boards on the Expedition - the surface is black plastic and they go from the back of the front wheel well to the back of the cab - I have the extended cab - 3 door - the guy told me they were factory Ford running boards - the brackets that are on them are L shaped.
Old May 27, 2008 | 04:20 PM
Lavern's Avatar
Lavern
Ok...maybe you could go see your dealer or if you have a friend with the same truck with factory running boards they should help you...If you could get a brand name I would check the web site.
CdnWillyG
37
Apr 12, 2015 03:29 PM
beefcake
Dec 11, 2010 01:35 PM
kjett
Offroad & 4x4
Feb 6, 2007 01:26 PM
JohnT
Dec 20, 2004 11:45 PM
