I'm pretty sure mine has a little seepage there also. I think you're fine. I would just check to make sure your tube isn't clogged or pinched and that the gases are venting freely.
Its not. It drips freely, and I can see smoke when I'm at a stop light. Also, the metal plate the hose end is up against has oily residue, so it is venting properly.
I know those are the ORings for the CCV, but my question is, will those fix the "problem" if it is a problem. Those orings on there are new from when I did the CCV mod.
It actually looks like the elbow is pointed up coming off the doghouse....if so, you could have oil puddling up and leaking out there, but the o-rings should keep it from doing that. Have you check the screws to make sure they are tight?
The elbow is pointed up, but it has to to get over the master cylinder, at least thats how it is in the Riffraff instructions..
Mine is pointed the same way but without the leak. I wonder if the o-rings slipped when you installed them and now it's seeping. There's only one way to find out...
Dont recall.. Theres a large amount of wires behind my air filter between the filter and the firewall. Think they go there. I have no idea what they do, think they are for the brake controller.
