What to do ?
Old Dec 22, 2020 | 10:41 PM
mcarb80682's Avatar
mcarb80682
What to do ?
What to do I leave to road trip on Christmas. But today I was getting the truck ready . I have 2000 v10.6.8. The bottom of my truck looks brand new no eaks till now.i noticed what looked like a residue on driver side under the EX . I looked around and notice what looked like a wet spot under her.don' know where its coming from I looked closer and it seems from it seems it's part of the water intlet bottom hose .what to do? Should I revisit after trip
Old Dec 23, 2020 | 07:11 AM
WE3ZS's Avatar
WE3ZS
A picture or two would be valuable here......
Its not uncommon for a 21 year old vehicle to have some drips and seeps happening, but your issue could be something more serious that could affect the upcoming road trip, no way for us to know from your vague description.
Old Dec 23, 2020 | 08:27 AM
seville009's Avatar
seville009
is it dripping while it’s cold and parked? put newspaper under it when it’s parked for the night and see if it’s wet in the morning.
Otherwise, it’s normal in hot and cold weather to have condensation dripping when you start up the vehicle, so if you see drips after moving the car, it may be just condensation.
Old Dec 23, 2020 | 08:49 AM
mcarb80682's Avatar
mcarb80682
Thanks for the reply. Its not dripping and I live in south Florida
Old Dec 23, 2020 | 09:00 AM
Mickey Bitsko's Avatar
Mickey Bitsko
Looks like my 00' 6.8 with 183k .. nbd
Old Dec 23, 2020 | 09:17 AM
mcarb80682's Avatar
mcarb80682
I have 140k The only thing different I did was run synthetic oil since they did not have synthetic blend on my last trip in Thanksgiving. That is driver side front by motor mount
Old Dec 23, 2020 | 06:20 PM
Cocky EX's Avatar
Cocky EX
Looks like it could be the oil cooler adapter gasket. I cant run full synthetic in my 6.8, it causes leaks that dont normally show to open up. Switching back to semi-synth may gradually make it stop seeping.
Old Dec 24, 2020 | 09:05 AM
ShelbyHauler's Avatar
ShelbyHauler
Hard to say, but if you go on your trip, I'd take some oil with you. I'm guessing you did check to see what it was that was on the ground? Oil and not water? You might take a socket and make sure the filter bracket is snug. Dont go crazy and break a bolt off before your trip, just make sure the bolt(s) are not backing out. I'm not sure what the torque requirement for that is.
My 04 V10 has 153K on it and I run full synthetic in it with no problems.
Old Dec 24, 2020 | 01:56 PM
mcarb80682's Avatar
mcarb80682
Thank you all. When I travel I always have oil with me . I did try to see if I can tighten the bold but they seemed already tight. I went to buy high mileage oil today just hate to waste new oil but I just remember I think I have Lucas oil in the gallon I will see if I do I might pour some to get the oil thickened. If I can't i will have to change the oil. But it's not dripping thanks god. Just my first oil leak in my excursion. I used to brag how my old truck was built so solid compare to new cars. It still has original water pump and dry under the engine
Excurvelle
Jun 1, 2020 04:02 PM
blackgold50
All Things Towing
19
Jul 31, 2014 07:43 AM
just another truck
48
Nov 26, 2008 11:20 AM
GoCamping
Dec 20, 2007 08:35 PM
tolie77
Dec 27, 2004 08:53 PM
