water dripping from bottom radator hose
The factory spring clamps on the radiator hoses are notorious for breaking (without looking broken) and allowing a small coolant leak. Might be able to fix it by replacing it with a standard hose clamp....if it's coolant. I'm not sure what else it could be, the engine doesn't contain any clear liquids.
If it's the infamous broken clamp, then note that the factory one is *glued* onto the hose. So you can be sitting there looking at two disconnected pieces of clamp sitting on the hose and yet they won't come off. (And if you're looking at them from below, and tug on them a little bit, you'll get a nice soothing antifreeze bath - ask me how I know.)
The glue will release with application of heat from a heat gun. I doubt a hairdryer gets hot enough. If you're good, you can put another clamp on the hose that will hold it in place while you remove the broken clamp pieces with the hose in place, then put *another* clamp on the hose to replace the cracked one, then take your backup clamp off. (If you are doing this to your second truck and successfully remove the broken clamp pieces and then try to *move* the backup clamp into the correct position, you will get a nice soothing antifreeze bath - ask me how I know.)
Duncan
Duncan
dobie6982
02-23-2009 09:22 PM
