Sponsored by: Auxito
No heat
Old Dec 10, 2020 | 06:47 PM
UncleBuck18's Avatar
UncleBuck18
No heat
I have a 2001 F150 with the 4.6 engine. I replaced the thermostat and the blend door IS working properly, and I flushed the heater core and I still have no heat. What else could this be?
Old Dec 10, 2020 | 07:21 PM
projectSHO89's Avatar
projectSHO89
Did you check for hot coolant flow through the heater core?
Old Dec 10, 2020 | 07:39 PM
UncleBuck18
Yeah, they both get hot over time
Old Dec 10, 2020 | 07:42 PM
projectSHO89
How hot over how much time?
Old Dec 10, 2020 | 08:02 PM
bbsitum's Avatar
bbsitum
Heat **** cracked or worn out. I slid piece of aluminum in and work since. I always tough people check that first.
Old Dec 11, 2020 | 09:59 AM
alloro's Avatar
alloro
Once the engine is up to full temperature those hoses should be too hot to hold. If you can hold onto them they're not hot enough.
Old Dec 11, 2020 | 10:51 AM
UncleBuck18
Between 10-15 minutes the inlet and outlet hose gets very hot to the touch, and I’ve noticed when I drive with both heat and air off and I turn it on heat it will blow a rush off hot air but then it gets back cold
Old Dec 11, 2020 | 11:52 AM
formerjeepguy's Avatar
formerjeepguy
What does your coolant look like and has it been changed regularly? Has it ever been brown? Has it been run on tap water alone?
I'm wondering if the impeller blades on the water pump have rusted away to nothing.
Old Dec 11, 2020 | 01:05 PM
UncleBuck18
Coolant looks like a nice lime green
Old Dec 11, 2020 | 01:10 PM
projectSHO89
At that point and with the blower still on high, check the temperature of the hoses.
Your basic symptom is of insufficient hot coolant in or passing through the core. Turning off the blower allows it to accumulate in the core and plenum. You need to determine whether or not here is a very substantial drop in the temperature of the outlet.
Old Dec 11, 2020 | 05:27 PM
UncleBuck18
So should I try flushing the heater core back out again? If the temp on the outlet hose decreases after the rush of hot air?
Old Dec 12, 2020 | 07:08 AM
formerjeepguy
you can try, but if your water pump isn't working right you won't get enough coolant flow through the heater core.
Old Dec 13, 2020 | 10:01 AM
alloro's Avatar
alloro
Like projectSHO89 said above, you need to feel the hoses again after the initial blast of heat goes away and the air gets cool again. If one hose is hot and the other cold you have a blockage in the heater core. If both are hot you have a blend door issue or scale build-up on the inside of the heater core.
cwalsh540
1997 - 2003 F150
Dec 14, 2020 01:43 PM
mlelah
26
Jan 10, 2015 02:27 PM
10actuxedo
1997 - 2003 F150
Nov 16, 2014 07:55 AM
COhunter
Aug 14, 2003 07:05 PM
Mudinyureyes
1978 - 1996 Big Bronco
Nov 18, 2002 12:56 AM
