==== 7.3 Towing Thread ====
Old Jun 28, 2021 | 01:07 PM
  #91
Hvyhaulr's Avatar
Hvyhaulr
I am new to towing, these are the only 2 loads I have carried so far.
Attachment 279727
Attachment 279728
Many have been concerned with the 15,500 lbs on the dana S135 axle.
Attachment 279729
This was around 19,500 lbs.
I hope to tow 2-3 rigs on a cross country off road trip one day.
And lastly, my inspiration for stupidity....
Attachment 279731
over 38k
Old Jun 28, 2021 | 03:33 PM
  #92
ESwift's Avatar
ESwift
CNCFAB
Man thats a load. I feel like my truck is a weak little turd just towing my 12,500 pound 5th wheel...
Old Jun 28, 2021 | 04:36 PM
  #93
FordTruckNoob's Avatar
FordTruckNoob
I get the feeling “Hold my beer.” will be uttered several times in this thread.
Old Jun 28, 2021 | 09:41 PM
  #94
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
You have a full size Jeep in the bed... You win!
Very fun thread to check in on.
Old Jun 28, 2021 | 09:49 PM
  #95
Hvyhaulr's Avatar
Hvyhaulr
Im not trying to win
Old Jun 28, 2021 | 09:56 PM
  #96
Sous's Avatar
Sous
FTE Emeritus
I showed my wife the picture and told her you were one of two fellas we were supposed to see in Boise. She too was impressed with the Jeep in the bed.
I look forward to seeing this mammoth truck in person one day.
Be safe out there sir.
Old Jun 29, 2021 | 09:36 AM
  #97
Hvyhaulr's Avatar
Hvyhaulr
Safe travels home!!!
Old Jul 9, 2021 | 03:37 PM
  #98
RyeThomas's Avatar
RyeThomas
Crayon Eater
Hauled the boat to the lake today. Now that I replaced all the parking brake components I’m far more confident at the ramp, that said I still shut the truck off and leave her in Low gear.
Really like this truck the longer I have her! She’s got character and is cool, can’t say that with a new truck. Well I’m a bit biased, lol.
Old Jul 9, 2021 | 03:54 PM
  #99
RyeThomas's Avatar
RyeThomas
Crayon Eater
Oh and I also meant to ask when do
you guys start in low vs 1? I feel like I can start in 1 but obviously I have to ride the clutch more or I can start in low, no clutch riding I just suck at my L-1 shift so not sure what’s best.
Guess work on L-1, don’t want to wear out the clutch.
Boat with all gear only weighs about 4K. Corse then I have 5 of us in the truck, a wife that packs way too much and screaming kids. Haha, I’m a lucky man.
Old Jul 10, 2021 | 07:53 AM
  #100
Sous's Avatar
Sous
FTE Emeritus
Anytime I have a load in the bed (firewood, concrete, etc) or am towing I always start from a stop in L.
Also, if I am on a steep incline at a stop I will use L as well. Just makes life easy.
Slowing to a stop, but not completely stopping i will start in 1st.
What RPM are you shifting from L to 1st at? Try various RPMs until you find what you are comfortable with. I will normally bring it up to 2500 or so and sometimes near 3000 in L. I also let the RPM settle for a fraction of a second before going into 1st.
My SB clutch is very different than the one that was in the truck and allows me to drive much more smooth. You will have to find your happy place.
I also rev match when up or down shifting.
When starting from a stop, you should be using very little to no clutch at all.
Old Jul 10, 2021 | 07:58 AM
  #101
Wes444's Avatar
Wes444
And very little to zero throttle
Old Jul 10, 2021 | 07:59 AM
  #102
SkySkiJason's Avatar
SkySkiJason
It depends. I use ‘L’ with heavy loads and sometimes on steep hills, but try not to rev very high, making transition to ‘1rst’ smoother.
I want to encourage you to stop reviving the engine and slipping the clutch like you would in a Honda. This engine will ‘rev up’ if you do not touch the accelerator and try to prevent a stall. Best practice is to release the clutch slowly enough to get the truck moving and then apply throttle. Learning to drive this way will save you a fortune in clutches. I seldom use the clutch except for leaving from a stop, but driving ‘smooth’ like this takes a good bit of practice.
Old Jul 10, 2021 | 08:04 AM
  #103
ESwift's Avatar
ESwift
CNCFAB
You guys should add a few tons of cinders and a heavy plow, and start out pushing deep snow. This requires lots of throttle and clutch at the same time
Old Jul 10, 2021 | 08:13 AM
  #104
RA101725's Avatar
RA101725
Banned
You can start out smoothly in 1st with 4-5k if it's a flat or downhill start with careful clutch modulation, but it will save the clutch and flywheel to start out in Low. Takes a little practice but basically all you have to do it get the truck rolling a tiny bit with Low and clutch it back up into 1st. No need to wrap it up real high or even take your foot away from the clutch pedal...a couple seconds up to 1000-1100 is enough for 1st to take over smoothly. For awhile I was in the (bad) habit of floating it out of Low without the clutch but if you bobble the shift with the clutch still connected, the driveline wont like that at all. Loud banging noises and potentially broken parts. Usually I will granny shift 1-2 as well and then 2 and above I will float it out of gear and clutch it into the next higher gear. Downshifting I'll will also float it out, blip the throttle and clutch it into the next lowest gear. Everybody has their favorite way to do it.
Old Jul 10, 2021 | 08:16 AM
  #105
Wes444's Avatar
Wes444
Towed 13k for 1700 miles this month, might have needed to use throttle starting in L to keep from stalling 5 times, those were all on very steep hills. Otherwise it'll usually get rolling without a stall by just letting the clutch out. At that point yeah, hammer down.
The 3-4 and 4 to OD seem to be the easiest to start practicing clutchless shifting by rev matching. Just slightly let off the throttle after maintaining throttle position for a second while applying light pressure to stick to pop out of gear, then when you are close to the right rpm a very slight rpm blip up will pop into gear with light pressure. May grind a bit till ya get the hang of it within 10 shifts or so, just don't force it in. You'll be surprised how easy it is after that
