ECT/EOT oil temperature alarm
Old Nov 12, 2020 | 11:34 AM
Jd1a's Avatar
Jd1a
Is there a dash alarm for temperature spread between the ECT/EOT? Posted this in the Excursion forum, may be better here.
Old Nov 12, 2020 | 11:41 AM
TooManyToys.'s Avatar
TooManyToys.
If I remember correctly, it depends on the level of OE programming you have if it will throw a service light.
Old Nov 12, 2020 | 12:02 PM
bismic's Avatar
bismic
TSB 09-24-3
Oil cooler efficiency monitor - DTC P012F stored and wrench warning lamp illuminated when the oil coolers efficiency drops below a specified threshold for a given speed and vehicle load condition.
Publication Date November 20, 2009
2005 F-Super Duty 6.0
2006-2007 F-Super Duty 6.0L
2005-2007 And 2009-2010 E-Series 6.0L
2008 E-Series 6.0
I don't see the Excursion mentioned as having it.
Old Nov 12, 2020 | 12:23 PM
TooManyToys.
I'm not up on all the programming changes Mark, any idea if the Excusions ever could have that program while not mentioned? It looks like limited to 2005+.
Old Nov 12, 2020 | 12:27 PM
bismic's Avatar
bismic
I don't think they did. Who knows if they ever had an engine replacement though.
Old Nov 12, 2020 | 03:00 PM
Jd1a's Avatar
Jd1a
Mine is an 03 and I'm the original owner. Most maintenance at the dealer except for the last two oil changes.
Old Nov 12, 2020 | 08:12 PM
Tennesseepowerstroke's Avatar
i bought my 03 new and have seen deltas of 22* difference without an alarm [223* -245*]. I replaced the fan clutch and the oil cooler and still see pretty much the thing with a 13,000 lb rv in tow on a 5 or 6 mile 6 percent grade hill. When unloaded my deltas show a 3 to 10 degrees difference with much cooler temps.
Old Nov 12, 2020 | 08:19 PM
TooManyToys.
The guidance target is only for empty at 60-65mph flat land. Vary from that, and the differential will increase.
Old Nov 12, 2020 | 08:55 PM
I realize that and it will definitely go up with a load behind it, but i wish the EOT wouldn't go this high, but what do I know. I have to wonder where it will go when i put the motorcycle trailer behind the 5th wheel, which I can do in Tennessee.
Old Nov 12, 2020 | 09:49 PM
bismic's Avatar
bismic
As I have posted several times - I can be driving 80 into a headwind, or I can be pulling a trailer (I don't pull heavy ones though), and I am still at 10 degrees or less differential. I have an OEM oil cooler.
Just a data point.
Old Nov 13, 2020 | 12:32 AM
Hartwig's Avatar
Hartwig
I have installed an Edge CTS 2, I see 12 parameters at a glance, a very reassuring tool for me. The alarm levels are adjustable on the device. ​​​​​​​
RetiredSoon
6.7L Power Stroke Diesel
13
Jan 5, 2024 12:34 PM
Bill Tex
Jul 27, 2020 01:50 PM
Nimrod
Feb 14, 2018 01:10 PM
mr. grieves
Nov 15, 2007 01:35 PM
FTE Ken
1997 - 2003 F150
Mar 10, 2002 12:50 AM
