Coolant issue
Old Nov 11, 2020 | 01:24 PM
dolansdj's Avatar
dolansdj
Coolant issue
On my 2006 Ford F250 super duty 6.0 I’m getting pressure buildup in the coolant were blows coolant out of reservoir my radiator was bad so I installed a new one also changed the Coolant reservoir cap I’ve done the die test to make sure The gasket wasn’t blown on exhaust side I’ve done a pressure test to make sure the gasket wasn’t blown on the compression side So far that stuff has passed but my upper radiator hose gets very tight not long before it gets up to running temp. Can my oil cooler Be an issue of this also the truck has been head studed I am EGR delete it. I just want to know what else I need to do or possibly check before I pull the cab thanks in advance
Old Nov 11, 2020 | 01:35 PM
Visurveyor's Avatar
Visurveyor
Why are you thinking of pulling the cab? Have you checked your thermostat. What are your operating delta's? Do you have a good code reader and monitoring tool? Post your dtc's and readings if you do.
Old Nov 12, 2020 | 05:16 PM
dolansdj's Avatar
dolansdj
the only code I'm throwing is a #5 glow plug. and I'm saying I want to know possibly what else to check before I pull the cab to do head gasket but something seems restricted im changing oil cooler tomorrow that's the last thing I can think of that would be causing coolant to keep getting pushed out the cap
Old Nov 12, 2020 | 05:34 PM
TooManyToys.'s Avatar
TooManyToys.
Hartwig has a good short video of a good testing method. the oil cooler is not going to cause the high pressure in the coolant system and cap bypass.
Old Nov 12, 2020 | 06:08 PM
dolansdj's Avatar
dolansdj
I did this test mine never got over 14psi from a complete stop to 95mph doesn't bubble but upper hose gets so tight you can barley squeeze it
Old Nov 12, 2020 | 06:21 PM
dolansdj's Avatar
dolansdj
so I was doing some research and it was saying if the oil cooler washed/plugged causing a restriction then it can cause excessive coolant pressure and also make I spit coolant out the overflow/ cap. but im new to the 6.0 world so any advise on testing helps.
Old Nov 13, 2020 | 12:43 AM
Hartwig's Avatar
Hartwig
Did you tested your degas bottle cap?
Did you backflushed your coolant system?
Before pulling the cab, check the EGR cooler.
If you need pictures for the EGR cooler test, I can show you some...
Old Nov 13, 2020 | 08:03 AM
dolansdj's Avatar
dolansdj
Mine is egr deleted And also just bought a new cap Two days ago from Ford
Old Nov 13, 2020 | 09:36 AM
87crewdually's Avatar
87crewdually
After the truck is at operating temperature (>186°f) get on a long flat highway and maintain speed (60mph) and after 15 minutes:
1. What are the oil and coolant temps? _________
2. What is the coolant pressure? _________
3. Now, release pressure from the degas cap and retighten, then run the truck (safely) up to speed at wide open throttle watching for a fast rise in coolant pressure. Slow your speed and repeat a run up to speed at wide open throttle observing the pressure of the coolant.
Now what is the coolant pressure and temps?
A. Pressure: _________
B. Temps: _________
As far as your oil cooler, this procedure above will help decide if there is an issue. If it is restricted enough it would slow coolant flow enough to make pressure but it should also reflect a high oil temperature.
dannyg1992
Oct 13, 2017 10:34 PM
Arlo2131
Feb 16, 2017 05:37 PM
aochoa1783
May 9, 2016 07:58 PM
Dodgehemi7
Oct 11, 2012 10:48 PM
caprocker
Jun 12, 2010 05:27 PM
