Starter..?
Old Nov 11, 2020 | 11:56 AM
timmyboy76's Avatar
timmyboy76
Starter..?
Need one now!
what auto store you recommend and type...duralast, valucraft...etc..
Old Nov 11, 2020 | 12:02 PM
ford390gashog's Avatar
ford390gashog
None of those!!! Don't be the next one stuck on the side of the road. https://cncfab.us/i-30497609-denso-g...8000-8420.html
If you need one now, then get it from Ford.
Old Nov 11, 2020 | 12:09 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by timmyboy76
Need one now!
Timmy, is a local remanufactured starter from a trusted shop an option for you?
I second that the Denso is the only way to go, but I too have been in the "what parts store should I gamble on" position in the past. If you must go parts store, I would say pick one that is most common around your new residence and trip to often traveled locations and has a lifetime warranty.
Old Nov 11, 2020 | 12:35 PM
Squirrel13's Avatar
Squirrel13
Denso from CNC Fab
Old Nov 11, 2020 | 12:36 PM
timmyboy76's Avatar
timmyboy76
Appreciate fellas...i have an old/Rom starter that needs a rebuild.
I went with an oreilly Ultima which says, a NEW Mitsubishi starter...so, it'll be suffice. Meantime, ill find a shop to rebuild the other since the new starter is only hitn me for a 10.00 core
..im replacing the existing oem starter in the L99. So, 21yr service i can't complain...seems lately, now that it's cold out in the mornings, it's been acting like a biatch. Finally grabs after a fee key turns. Started showing its face back in mammoth(cold mornings)...
Old Nov 11, 2020 | 12:40 PM
Squirrel13's Avatar
Squirrel13
Sometimes you have to look at the long run and see what makes sense for some parts. I don't plan on doing a starter again. My daughter will inherit the Ex some day when I pass. Now batteries I chose the Walmart AGM. Reasonable price, warrantied pretty much everywhere I might be.
Old Nov 11, 2020 | 12:42 PM
timmyboy76's Avatar
timmyboy76
If not in the position im in at the moment, I could let truck sit til a CNC Fab starter was delivered but, I'm booked with homes til mid December and the 02 I have, won't work(need ladder rack)
.....not doing the homes today, eff me for tmrw. Now, I have 7 to do to keep on track
...this the reason for the pucker factor...
Old Nov 11, 2020 | 01:08 PM
Squirrel13's Avatar
Squirrel13
Old Nov 11, 2020 | 01:21 PM
timmyboy76's Avatar
timmyboy76
Bwahahaha....
"can't get this damn thing to work"
mattymax
Jan 11, 2016 11:10 AM
Twotall
26
Sep 24, 2014 06:58 PM
otpracer
Oct 17, 2011 09:31 AM
vze2sgxa
Oct 28, 2010 07:15 PM
dship
1997 - 2003 F150
Aug 31, 2005 05:54 PM
