Another surging at idle problem
Old Dec 5, 2020 | 04:40 PM
  #136
jstihl's Avatar
jstihl
Thanks Sous, that's what I was thinking also, eliminate these codes and hopefully it will lead me somewhere. I have 2 transfer case codes, 2 alternator codes, and now 2 front left wheel speed sensor codes. My plan of attack is as follows:
-replace the faulty ground cableClear codes and see if that eliminates any of them - send pcm to Johnathan and make sure it's up to par being that the FSM is pointing to the pcm for the alternator codes. - look into the transfer case codes.
I put the transfer case codes last because the wiring /clips seems ok and replacing the solenoids are( most likely) going to be costly.
Hopefully somewhere along the way the vibration/ surging will show its ugly head.
Old Dec 9, 2020 | 10:16 AM
  #137
jstihl's Avatar
jstihl
I changed the ground cable and that didn't help anything. I noticed my idle is always raising up to 1000 rpms alot lately ( which I know is normal in winter months but I'm in florida and my f450 does not do this nearly as much). It was 60 degrees today when I started the truck and my IAT is reading 32 degrees, is that because of the intercooler? I wasn't sure where the IAT reading was taken from, thought it was at the filter?
On edit: MAT would be the temp sensor affected by the intercooler so it sounds like my IAT has gone bad. I will try to track one down and see what that does
Old Dec 9, 2020 | 11:57 AM
  #138
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Is your EOT sensor working properly?
Old Dec 9, 2020 | 12:36 PM
  #139
jstihl's Avatar
jstihl
EOT seems to be ok. MAT was reading 55 degrees but IAT was reading 32 at start up which I believe is why the RPMs keep raising up to 1000. Probably has nothing to do with my problems but just trying to find any little thing that is wrong before I send the pcm to Johnathan. Really worried that there is something internally wrong with the engine but it cranks nice and even and there is no puffing coming out of the oil fill tube. There is quite a bit of smoke that comes out of the oil fill but it's not puffing at all. I did get a glow plug DTC yesterday but forgot to save it to my phone. Forscan said there was a open in the glow plug circuit so I will have to look into that. It's weird how I keep getting these different codes, I had the brake on off code but it hasn't come back, had 2 front left wheel speed sensor codes but they haven't come back, now this glow plug DTC. I do have a voltage drop when the glow plugs are commanded on and then after a minute when the glow plugs go off the voltage goes back up. Trying to find out as much information as I can for Jonathan when I send in the PCM
Old Dec 9, 2020 | 02:19 PM
  #140
jstihl's Avatar
jstihl
Is it the eot that raises the idle or the ambient temp?
Old Dec 9, 2020 | 02:29 PM
  #141
ESwift's Avatar
ESwift
CNCFAB
Eot is used for idle rpm and what not
Old Dec 9, 2020 | 02:31 PM
  #142
FinnishStroker's Avatar
FinnishStroker
PCM can use both, EOT and IAT,to control idle.
Atleast for my RCU0 box..
Old Dec 11, 2020 | 05:00 PM
  #143
jstihl's Avatar
jstihl
You were right finnish, IAT does control high idle, a new sensor stopped the high idle and is reading correct now👍
Old Dec 11, 2020 | 05:09 PM
  #144
jstihl's Avatar
jstihl
So just brainstorming here, trying to think of anything else that would put a load on the engine. The glow plugs seem to be cycling on/ off but there is a different release of load on the engine when they turn off. The a/c clutch is working properly and spins freely when it is off. The power steering pump is new. The water pump looks new. Lower alt is new and the top one looks newer, both pulleys spin freely when belt is off. I pulled the belt off and started the engine for a minute, the vibration is still there but it is not as bad and the engine seems to run more freely. Is there anything else that I am missing here that would cause a load on the engine? Tranny was just rebuilt. Being that I'm not getting complete voltage to both alternators from the pcm signal I wonder if this could somehow cause something to go into default having them work extra hard? Anything I am missing? You know When you push the brake and turn the steering wheel when your in park it kind of boggs the engine down some, well that's what it feels like all the time at idle.
Old Dec 11, 2020 | 05:41 PM
  #145
Sous's Avatar
Sous
FTE Emeritus
jstihl, you have been through the wringer with this thing...
Have you seen this recent post by Z31Freakify: https://www.ford-trucks.com/forums/1...l#post19619405
Not saying that is your issue, but it is free and easy to check the condition of those parts.
I know you thought you identified the vibration source by listening to the flywheel area, have you tried a mechanics stethoscope, hose or something similar to try and narrow the vibration down further to an area of the engine bay?
I was browsing through the PC/ED volume of the FSM and have attached pinpoint test AF which was identified by symptoms "rolling idle" and "runs rough at idle". Maybe this will help... I don't know what else to say sir, sorry...
Old Dec 11, 2020 | 07:09 PM
  #146
jstihl's Avatar
jstihl
Thanks Sous, I will go through those links and see what I can find. Went through all the engine mounts / cab mounts again today hoping to find something but no luck. Also read through all 16 pages of kubota Orange's thread" shaky at idle when hot" last night. It's a bummer that so many of us have these problems at idle but the solution is so elusive. I noticed bbslider mentioned in that thread that someone he knew changed out the wiring harness and that helped tremendously but not sure how much of a nightmare job that is. I am afraid to keep sinking money into this truck for fear that there is something seriously wrong internally so I may just have to live with it. Given how stubborn I am I'll probably end up replacing everything on the truck though, just more time and money. 2 things I need a lot more of.... Thanks again for all the help, if I find anything out I'll be sure to post hopefully good results 🤞
Old Dec 11, 2020 | 09:52 PM
  #147
udsuth78's Avatar
udsuth78
Reading this post reminded me of a recent diagnostics issue I was having with an oilfield engine. I don't know that it would have any bearing in your troubles, but it does ring a bell.
The engine would start and run ok, but seemed off a little. Didn't idle well but with a load mostly ok. One day out of the blue the engine was down and battery was down. Got it going again but alternator was only putting out 12.4v. It would stay running anywhere from hours to days, so I swapped the alternator and no change. I suspected the battery but it always held a charge and didn't show any signs of a short or dead cell. So I started troubleshooting wiring, found some suspects and fixed them but still had the same issues. On a whim I hooked up a different battery,(not even a good one) and problem solved. Alternator immediately started putting out 14.6v and the other quirks went away too. The weird part is that battery is still sitting there with 12.2 volts unhooked for over 2 weeks. I can't explain the how or why and I'm still scratching my head about it, but it's working so I leave it alone.
Old Dec 12, 2020 | 07:57 AM
  #148
jstihl's Avatar
jstihl
These trucks definitely do some really off the wall stuff that's for sure. Alot of times it's just a trial and error procedure but sometimes you get lucky and you gotta just roll with it. I bought this truck knowing it would be a project but I think I bit off a little more than I can chew. The truck runs 2000 times better than it did thanks to FTE, but this problem has me scratching my head for a year now. I will figure it out...... One day....😬
Old Dec 12, 2020 | 08:04 AM
  #149
jstihl's Avatar
jstihl
I did see that post by z31freakify and ironically a fuel bowl re seal is about the only thing I haven't done yet. I did clean the brass poppet real good when I installed the frx though. I have a steady 69 psi and only drops to 60 at WOT . I already have the fuel bowl re seal kit so might as well give the poppet kit a try also. If anything it's good preventive maintenance 👍
Old Dec 12, 2020 | 08:12 AM
  #150
RacinJasonWV's Avatar
RacinJasonWV
Sorry for a possibly stupid comment...
Is it possible to run just one alternator? I’m thinking a different belt just for the single setup. It seems you said the load from them made a change.
Or since they both turn freely possibly just disconnect (and tape up) the wiring from them one at a time to see if there’s a change. Double alts can be a good thing but they could also be hiding an issue with one of them.
Just a thought and it’s free to try the disconnect.
