Sponsored by: Real Truck
Caliper bracket mounting bolts
Old Oct 29, 2020 | 08:15 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Originally Posted by PJWhelan
Most if not all fasteners on all Ford Trucks (bolts, nuts, washers etc) will be Metric. Try any big Hardware store (no, not Lowes or HD) try ACE hardware, Fastenal, Grainger. Obviously there are also online Fastener warehouses so there you go.
PJ
I still wouldn't put any old fastener in there, as these are pretty specific kinds of bolts. And $8/bolt doesn't seem all that bad considering how relatively expensive these bolts are to make.
Let me put it this way, a common 1/4-20 bolt, 1" long, can be bought for a dime because they make MILLIONS at a time. A 6" long 1/2-13 bolt, fully threaded, is $5-7/bolt because they don't make nearly as many of them - there's just not as much use for a bolt that size, even though it's a common style.
A 16x1.5 metric bolt, 54mm long, with a special shoulder (diameter and length both held to probably less than 1mm) to locate a bracket, and a special flange to spread out the load and not destroy said bracket when torqued, is unique to just a couple applications. The fact that it's only $8 almost feels like a good price.
Old Oct 29, 2020 | 11:10 AM
projectSHO89's Avatar
projectSHO89
Not to mention strength/hardness requirements and corrosion resistance.
Buy a bolt made for the purpose at hand for anything except a very temporary emergency repair.
Old Oct 29, 2020 | 01:25 PM
crusty old shellback's Avatar
So let me get this strait.
You want to "cheap out" on a bolt that holds the braking system together on your truck?
Have you ever had one of the bolts come out and see what happens?
I have. I got lucky in that it was the lower bolt and not the top bolt. I didn't find it until I went to back up and the caliper dug into the rim and stopped the truck. Imagine if it would have been the top bolt and I hit the brakes going 60 MPH? I'd probably been thrown thru the windshield as the tire locked up and went skidding off the road somewhere. And yes, I found the issue after traveling some back roads at 60 + MPH. pulled into a truck stop to eat and couldn't back up.
The bolts also have a special locking compound on them. Both the OEM and the aftermarket ones I got from o'rilley auto.
Old Oct 30, 2020 | 12:18 PM
mark a.'s Avatar
mark a.
Bell Metric is the only place I get metric bolts from anymore.
Old Oct 30, 2020 | 03:21 PM
99powerstrokedF250
Good point, I did leave out those points as well.
jejenkins417
May 12, 2022 08:21 PM
lopealle
Nov 12, 2013 10:32 PM
Wyokaboy
Dec 15, 2007 10:59 PM
Alan'sExpy
Jul 29, 2007 09:21 AM
hydrology_joe
1983 - 2012 Ranger & B-Series
Jan 9, 2006 08:37 PM
