Sponsored by: Real Truck
Caliper bracket mounting bolts
Old Oct 24, 2020 | 09:28 AM
fdude64's Avatar
fdude64
Okay I have a question regarding the caliper bracket mounting bolts. My local garage says they are a 16 mm by 54 mm bolt. I come up with my measurements I'm 5/8 by 2 so who is correct and where would I buy these bolts my local dealer does not have any in stock they can't tell me the size all I can get is the part number
Old Oct 24, 2020 | 10:03 AM
fdude64's Avatar
fdude64
I'm sorry I forgot to mention it's a 2000 F-350 r7.3 liter diesel crew cab single rear wheels front calipers
Old Oct 24, 2020 | 12:20 PM
Djosbun's Avatar
Djosbun
The bolts are metric, so the shop is correct.
-- Dave
Old Oct 24, 2020 | 01:19 PM
projectSHO89's Avatar
projectSHO89
Metric, metric, metric. You're using the wrong measurement standard. Ford switched almost everything over to metric back in the 70s and 80s.
Front and rear are the same. You can buy them at O'reilly's.
Old Oct 25, 2020 | 10:23 PM
fdude64's Avatar
fdude64
the rear bracket mounting bolts on mine are smaller
Old Oct 25, 2020 | 10:35 PM
fdude64's Avatar
fdude64
Still trying to figure out what size they are
Old Oct 25, 2020 | 10:37 PM
ford390gashog's Avatar
ford390gashog
Well the dealer gave you the part number, I would have just ordered them then. These bolts are not easy to get and the Dorman replacements are not the same quality.
Old Oct 26, 2020 | 07:19 AM
fdude64's Avatar
fdude64
that is why I'm trying to find what size bolts they are so I can avoid getting the Dorman bolts and find some good quality bolts to replace them with. My dealer was almost $8 a bolt
Old Oct 26, 2020 | 09:00 AM
crusty old shellback's Avatar
I got mine at orilleys. haven't had any issues with them since I installed them.
Old Oct 26, 2020 | 10:51 AM
99powerstrokedF250's Avatar
99powerstrokedF250
They're not a bolt you can just buy at the hardware store. They're a special grade, with a wide flange to spread out the clamping force, and if I recall they have a special length and diameter shoulder that helps locate the bracket properly. You're going to want to order them from your dealer or search online, there are several dealers that sell their overstocked parts at a reasonable price.
That said, the shop told you what the bolts are. They're a 16mm thread, standard thread is 2.0 but I'm pretty sure these are fine thread so probably 1.5, and 54mm long. If you really want to put standard bolts in there you can, but I wouldn't do it long term.
Old Oct 26, 2020 | 12:18 PM
fdude64's Avatar
fdude64
I was going to try and order them online maybe find a better deal
Old Oct 26, 2020 | 01:45 PM
ford390gashog
Well 8.00 a bolt is very reasonable for these, these are not common fasteners.
Old Oct 26, 2020 | 10:25 PM
AK4x4's Avatar
AK4x4
I would go here https://parts.autonationfordwhitebearlake.com/ and look for your part number. Good Luck, Russ
Old Oct 27, 2020 | 05:47 AM
Just Strokin's Avatar
Just Strokin
front caliper bolts at White Bear
https://parts.autonationfordwhitebea...wtdjgtZGllc2Vs
Old Oct 28, 2020 | 08:48 PM
PJWhelan's Avatar
PJWhelan
Most if not all fasteners on all Ford Trucks (bolts, nuts, washers etc) will be Metric. Try any big Hardware store (no, not Lowes or HD) try ACE hardware, Fastenal, Grainger. Obviously there are also online Fastener warehouses so there you go.
PJ
