Rear caliper BRACKET bolts, need part #, HELP!
Old 06-28-2011, 02:40 PM
jejenkins417
jejenkins417 is offline
jejenkins417 is starting off with a positive reputation.
Local dealers....plural can't seem to get the right part in for me and I'm needing it bad.
I need the rear caliper "BRACKET" bolt, not the caliper slide pins or bolts but the actual bracket that bolts to the spindle.
Anyone have a part #? I've started a discussion with FTE vendor but they came up with slide pin #'s. The part #F81Z-2N386-BA is NOT what I need.
Jon
Old 06-28-2011, 02:55 PM
jasonodsky's Avatar
jasonodsky
jasonodsky is offline
jasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to behold
Not a 100% clear. Do you just need the bolts that hold the bracket to the rear axle or the bracket itself? The bracket is available from Napa CAL N141563.
Old 06-28-2011, 04:54 PM
jejenkins417
Just need the bolts.
Old 06-28-2011, 08:26 PM
jejenkins417
So far have come up with part #F81Z-2N386-BA and part #W710862-S439
The first one description when googling is guide pin retainer. the second one is a bolt but can't seem to figure out if it is the bolt that goes into the guide pin or the actual bolt for the bracket.
I have been searching for hours and the bolts I picked up from the dealer where too big (diameter and length).
Anyone.....
Old 06-28-2011, 08:47 PM
jejenkins417
I found a diagram of the bolts I need. http://ww2.justanswer.com/uploads/s4...chor_plate.pdf
I guess it is referred to as an "anchor plate"
I'll try our dealer again tomorrow with this description and take the picture in..... then maybe they will get it right.
Old 06-21-2013, 10:33 AM
trailblazer95's Avatar
trailblazer95
trailblazer95 is offline
trailblazer95 is starting off with a positive reputation.
Sorry to revive an old post, but has anyone been able to find a part number for the rear caliper "anchor plate" bolts? Or any leads? My dealership sold me the wrong ones, twice. Anybody have any helpful info? I need one!
Old 08-07-2013, 06:49 PM
trailblazer95
Just to update those who may need this in the future:
Part #W710862S439 worked for me.
Old 08-29-2013, 05:39 PM
AndrewWV's Avatar
AndrewWV
AndrewWV is offline
AndrewWV has a very good reputation on FTE.AndrewWV has a very good reputation on FTE.AndrewWV has a very good reputation on FTE.AndrewWV has a very good reputation on FTE.
Thank you! Thank you! Thank you! I need one of those myself and was trying to find a part number to make sure they get the right one the first time.
04-05-2016 03:08 PM
Capt.Schenk
03-24-2016 09:52 AM
Capt.Schenk
02-24-2015 09:13 AM
labman1014
07-11-2012 12:25 AM
whalerron
1999 to 2016 Super Duty
12-27-2011 08:52 AM
Quick Reply: Rear caliper BRACKET bolts, need part #, HELP!
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
