68 f250 rwd. Tire size/rims question
Hello all. I believe they are the 16.5 rim..I'm not 100 percent sure and I'm not around the truck but I'm going to keep the rims but id like some aftermarket ones with slightly taller and wider tires than original. Any ideas? I'm not a wheel person so that's why im asking for ideas. Not sure of clearance but it has power brakes on front. Drum in rear
265/75R16 is pretty much identical in diamater to the 7.50-16 that came on the lowest rated 250 that year, but is a little wider. A 235/85R16 is a direct replacement to a 7.50-16 in diamater and width. One with 16.5s would have an 8.00x16.5 and a 265/75R16 would look right, and be a little wider than stock. You might fit a 285/75R16 but ANY modern tire is going to look or be wider than what you have
I think the 90's steel wheels still fit the dog dish caps from years before as well. If you want to keep original caps.
on
Originally Posted by 3000gtman
What about 285/85R16?
255/85R16 would fit. But they are hard to get.
285/75R16 would also fit. And that's a common size.
I will buy aftermarket rims but what the bolt pattern? Or any recommendations on rim? I like the stock look..nothing fancy.
Again, I HIGHLY recommend going with a 17" or bigger wheel. Some aftermarket 16s can interfere with the front brakes. Not to mention that 17, 18 and 20 inch tires are the norm nowadays.
Alright fellas...I'm pretty certain I have split rims. So I will replace them but the tire size will be 285/70/17 is there a way to get decent rims that I can still use the original hub caps? I'm not educated in wheels at all. I like the original look of the truck but I would like beefer tires. It's 2wd tho. I'll double check the split rim situation but I'm 90 percent sure they are splits.
Schneivly
15
12-01-2015 11:06 AM
rustyleerusk
08-22-2015 11:58 AM
66flareside
09-14-2008 10:03 AM
