wheel sze
Old Feb 26, 2005 | 08:25 PM
mike9762's Avatar
mike9762
wheel sze
i am getting new rims for my 77 f250 highboy 4x4,they will be 16" x 7"-8 lug with a 6 1/2" bolt pattern.....but does anyone know what the offset is?
p.s i have front disc and rear drums if it matters.....thanks for any help
mike
Old Feb 26, 2005 | 09:26 PM
stretch351c's Avatar
stretch351c
I believe that the offset depends on tire size. I have 16x7 rims with 265 75 16 Lt's on my 76 F250 2wd and they're just a standard replacement for the old split rims. I don't have any problems with tire rub at all. So unless you plan on using some radical tires I think the standard offset should be fine.
Old Feb 26, 2005 | 10:21 PM
mike9762's Avatar
mike9762
tire size now is 235/85/16 would keep this size
Old Feb 26, 2005 | 10:38 PM
stretch351c
You should be fine then. No problems as those are the stock tire size I think
Old Feb 26, 2005 | 10:48 PM
mike9762's Avatar
mike9762
and what about backspacing?
Old Feb 27, 2005 | 11:42 PM
stretch351c
Like I said Unless you special order the rims they're going to be stock spec rims and with that tire size you shouldn't have any problems at all
Old Feb 28, 2005 | 07:53 AM
mike9762's Avatar
mike9762
thanks stretch u really helped, i appreciate the time and knowledge
mike
Old Mar 1, 2005 | 07:02 PM
stretch351c
No problem this what this website is for. I've already gotten alot of info and help from everybody here. Some of it doesn't apply to what i'm doing but you never know what helps and what doesn't untill you try it out. Good luck and have fun.
