changing rims
Old Aug 21, 2015 | 06:18 PM
rustyleerusk's Avatar
rustyleerusk
changing rims
my truck (82 f250) came with 16.5x8 rims with 33/12.5r16.5 tires. Since 16.5 are almost non existent i plan on changing them out. I have a 16x6 rim that fits the front but just barely clears the brakes. The tread separated on one of the fronts so i was going to change one at a time. Is there a tire that is as tall as a 33 but will fit on a 6 inch rim? is there a minimum clearance between the rim and brakes or as long as it turns it's ok?
Old Aug 21, 2015 | 08:34 PM
Nothing Special's Avatar
Nothing Special
I've always figured that as long as it turns freely it's OK.
As to width, general rule of thumb is that the tire section width (the width in the size designation of the tire) should be about 2" wider than the rim, although you can push that a bit. So a 6" rim should have about an 8" or a 205 mm wide tire. I'm not sure what's available in a 205, and as I said, you can push higher than that with the risk of a little worse tread wear and a little worse handling. But it's not like it goes to pot if you're 2.5" wider or anything. In fact a lot of people put 12.5" wide tires on 8" rims and claim it's fine (although I'm not advocating it)
Old Aug 21, 2015 | 08:59 PM
Diesel_Brad's Avatar
Diesel_Brad
If you get stock ford rims from a 92-97 they are 16x7"(just a touch wider) 94-97 had the factory Alcoa aluminum rims
285/75/16s are basically 33" tall
Just a FYI MOST 33" tires are NOT 33". they are more like 32 when new and get smaller with wear
As for rim to brake clearance. 1/8 is all you need. And the brakes are the same from 80-94. In 95They actually got 1/2" bigger
Old Aug 21, 2015 | 09:02 PM
Franklin2's Avatar
Franklin2
Your tires will probably rub the front leaf springs if you use those narrow rims that are set to the inside of the truck with a wide tire. And if you get a tire that is too wide, the middle wears out before the edges of the tire.
Best rule of thumb; If you are going to use stock rims, use stock size or very near stock size tires. If you want large aftermarket tires, use aftermarket rims. It works so much better.
Old Aug 21, 2015 | 09:33 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Stock dually tires were 215/85 R16 if you need something E rated....
Old Aug 22, 2015 | 11:58 AM
rustyleerusk
Problem solved. I had a 16x7 rim given to me and a slightly used 285/75r16 tire/mount/balance for $50. that should get me to work and back plenty safe till i can replace the rest to match. Thanks for all the comments!
Gear619
Mar 10, 2015 01:44 PM
powerstroke02
Apr 12, 2008 07:20 PM
Superfuzz
1997 - 2003 F150
Feb 18, 2004 10:26 PM
xplod33
Jan 26, 2003 12:48 AM
IES
Jan 2, 2003 09:26 AM
