Sponsored by: Real Truck
New Keys for 2013
Old Oct 13, 2020 | 01:41 PM
BigBlue99's Avatar
BigBlue99
New Keys for 2013
bought a 2013 F250 and it only came with 1 key. i want to get some spares made and the locksmith told me it could run upwards of 400 per key and i figured that the dealer would be worse. i would be fine with a basic key no fob/unlock buttons as long as it would not set the alarm off when used to unlock the truck. Can the alarm be disabled completely? last truck did not have alarm. where is the best place to get spare keys? is 400 a realistic number?
Old Oct 13, 2020 | 03:39 PM
Just Strokin's Avatar
Just Strokin
You can buy 80 bit Ford security keys off eBay for less than 10 each....sometimes i have seen then for like 2 for 12 or 15 dollars....you can get the cut at your local locksmith or hardware store for a few dollars each (no programming)....you can buy a bluetooth OBDII adapter, install FORScan on a laptop and then program your keys.
Read this thread and see how it is done
Erase All PATS Keys 2016 F250 XLT - Ford Truck Enthusiasts Forums
The lock/unlock buttons a fob (not one of the IKT's) are a separate function that is not based on a key being programmed into PATs. When you program an IKT it usually programs the buttons on the fob also.
IKT - Integrated Key (has chip and luck/unlock and maybe remote start buttons)
Old Oct 14, 2020 | 01:06 PM
Fatz29708's Avatar
Fatz29708
I have had luck programming additional keys when just having one, the key is to make sure the one you have isnt programmed to set you seats and stuff when you hit the button, go thru the process in the owners manual and reinsert the same key as if you had two.
Forscan process is probably much easier, also if it was a used truck the old owner can stalk you and come take the truck for a ride, probably drop some french fries between the seat and console, you know, that black hole you can NOT get to.
Old Oct 14, 2020 | 02:24 PM
Rubyvette's Avatar
Rubyvette
I just got a quote from a dealership for $275 for the key with remote lock/unlock and remote start on it for my 2016 F350. $400 sounds a bit high.
Old Oct 14, 2020 | 04:38 PM
Fatz29708's Avatar
Fatz29708
way high, the key is like $20, you can program yourself for free, PH them dealers!
Old Oct 14, 2020 | 04:45 PM
ford390gashog's Avatar
ford390gashog
You can wipe and program keys with Forscan, the key blanks are cheap new.
Old Oct 14, 2020 | 05:42 PM
Just Strokin
Here are listings on eBay for the IKT's. You have to select the one you need as some on remote start, some have cargo door opener and some are just 3 buttons
https://www.ebay.com/sch/i.html?_fro...R8067&_sacat=0
Here is a listing for two standard 80 bit PATs keys for less than $11.
https://www.ebay.com/itm/2x-Ignition...EAAOSw1TFfL~Jf
Old Oct 14, 2020 | 07:02 PM
96_F250_Deezal's Avatar
96_F250_Deezal
I programmed new keys for my 2011 Superduty and added factory remote start. Verify easy with FORScan software.
Old Oct 15, 2020 | 11:28 AM
BigBlue99's Avatar
BigBlue99
i talked with a local ford mechanic and he recommended ford chipped keys only because of hit and miss luck with ebay/amazon keys.
ended up making an appointment with the dealership. 135 per key with the buttons, 25 per basic key, and 75 to cut and program.
Old Oct 15, 2020 | 04:45 PM
Just Strokin
Never had any problems with standard 80 bit chip keys off eBay. I am using them on my 2015 pickup instead of that big key fob with the buttons.
Richard Emil
Jul 9, 2018 08:54 AM
Ed Woods
2009 - 2014 F150
Jan 2, 2017 06:23 PM
khadma
2015 - 2020 F150
Dec 24, 2015 05:02 PM
flixden
2009 - 2014 F150
37
Aug 23, 2012 08:50 AM
clogee
1997 - 2003 F150
Nov 30, 2003 10:32 AM
