Sponsored by: Real Truck
Powerstop brake issue
Old Oct 15, 2020 | 12:50 PM
MTP55's Avatar
MTP55
I just put new Powerstop brakes on my truck last weekend. Had a soft pedal issue after bleeding. I should have thought about it but I didn't, the right side rear caliper is incorrect, the bleeder faces down as it is the same caliper as the left side. I had to send the truck in to get new steel lines put on the rear axle and they called to let me know they couldn't because they wouldn't be able to bleed it. Its my slice of humble pie for the week i suppose. Does anyone else have these brakes on their truck and have a remedy or correct part number? Its a 2000 F250.
Old Oct 15, 2020 | 02:21 PM
don123's Avatar
don123
Go to rock auto.com. Put your info in and it will give you the correct part number. I installed the coated calipers and rotors a couple of months ago . They work great so far.
Old Oct 15, 2020 | 02:32 PM
MTP55's Avatar
MTP55
I sent an email to customer service to see if they will send me the right caliper. Hopefully I can get it here soon.
Old Oct 15, 2020 | 05:54 PM
Djosbun's Avatar
Djosbun
Did you order the wrong caliper or did they have the incorrect caliper packed in the box (which happens often when someone buys both sides, takes them out of the box and decided to return them)?
I'd just complete their return form and order the side you need if time is of the essence. If the mistake is on their end, I would figure they'd refund the shipping charge since you already ordered the replacement.
-- Dave
Old Oct 15, 2020 | 06:04 PM
MTP55's Avatar
MTP55
-- Dave
Theyre supposed to fit my truck but apparently mine and my bosses both got a leftover L99 axle or something.
devo2810
May 20, 2018 03:40 PM
tjc transport
Jul 2, 2016 09:12 PM
poq-ff-19
Oct 18, 2013 12:28 PM
ghunt
30
Feb 2, 2009 01:25 AM
gtripledip
Dec 3, 2006 09:32 AM
