Injector circiuit low
Old Oct 7, 2020 | 01:21 AM
JaySVX's Avatar
JaySVX
I'll be driving my truck down the road and all will be fine, then suddenly misses, steady for 2-3min, then it goes away. Mean while I'm monitoring everything and nothing seems strange. So I decide to do a buzz test, thinking an injector is bad. The code list I get back is crazy, P0261-P0282, every cylinder says injector circuit low. Mean while when this happens my FICM shows a solid 48.5v. I repaired my FICM 10 years ago and it has been flawless since. I checked the connectiosn to make sure they were snug, and all was good. I don't see how it's possible that every single injector has a low voltage, it would have to be somewhere else. I'm not aware of anything between the FICM and the injectors though.
Can anyone shed some light on this?
Old Oct 7, 2020 | 02:24 AM
Hartwig's Avatar
Hartwig
clear codes,
check FICM voltage while driving,
check alternator voltage.
Old Oct 7, 2020 | 04:10 AM
Yahiko's Avatar
Yahiko
The FICM is not just a voltage device. It has a lot of logic in it also.
So you can have a logic issue going on and still have good voltage.
Old Oct 7, 2020 | 06:24 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Sounds like your logic side may have taken a dump. I had a customer a few years ago that the injectors would occasionally buzz KOEO. Power side showed a steady 48-49 volts but his logic side was toast. Another shop replaced the Ficm and he was back on the road.
You may also check the wiring harness under the Ficm itself. On some 2004 trucks the rear of the plug may be exposed causing chaffing. It was a common thing on the 2004 trucks. They ended up rerouting the engine harness that year because of the chaffing.
Old Oct 7, 2020 | 01:06 PM
JaySVX's Avatar
JaySVX
Originally Posted by Hartwig
clear codes,
I monitor my voltage al the time with the torque app, when it happens the ficm voltage is still a solid 48.5v
Old Oct 7, 2020 | 01:32 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Data on the bus has two “states” low or high. I think the fault code doesn’t refer to a low voltage problem but to a data issue.
maybe three states, I think there is a null also- neither hi or low.
Old Oct 7, 2020 | 02:23 PM
bismic's Avatar
bismic
I think he was suggesting to monitor the logic voltage as well as the main voltage (FICM LPower).
Old Oct 8, 2020 | 09:59 AM
JaySVX's Avatar
JaySVX
I'll see if I have that as an option.
Here's a little video of when I'm driving. It seemed to be consistent yesterday. https://i.imgur.com/zCyUes8.mp4
Old Oct 9, 2020 | 12:52 AM
Hartwig's Avatar
Hartwig
I mean there are more parameters for the FICM. Please check if forscan can display more pids for the FICM
uglypitbull
Sep 30, 2020 09:10 PM
Mike Bartlett
Jul 26, 2019 03:15 PM
Royson12
Oct 21, 2017 07:46 AM
invintive
Jan 28, 2017 10:35 PM
delimiter
Apr 7, 2007 06:01 PM
