Sponsored by: Real Truck
Oil change debacle
Old Oct 3, 2020 | 02:34 PM
Uconnrick's Avatar
Uconnrick
Oil change debacle
Changed my oil uneventfully this AM. Started and ran it for 5 seconds, no leaks or check lights. Tried to start it 10 minutes later and it won't start. It sounds like the starter is engaging and disengaging. If I didn't drain the oil myself, I'd swear it was hyrolocked.
Checked for codes and there are 30 codes showing, none of which my reader can help with. WTF did I do?
Old Oct 3, 2020 | 02:35 PM
seville009's Avatar
seville009
maybe you bumped into some connection and knocked it loose. check the whole area you worked in and crawled under the truck by
Old Oct 3, 2020 | 02:50 PM
bwguardian's Avatar
bwguardian
What engine?
Old Oct 3, 2020 | 03:00 PM
Uconnrick's Avatar
Uconnrick
Originally Posted by bwguardian
What engine?
It's a 2016. Thanks.
Old Oct 3, 2020 | 04:08 PM
Just Strokin's Avatar
Just Strokin
see if any of the codes are listed here....
http://www.fordservicecontent.com/fo...DOBDSM1601.pdf
Old Oct 3, 2020 | 10:59 PM
Uconnrick's Avatar
Uconnrick
OK now.
Turns out that my first thought was correct. The batteries were too low to turn it over. I had never see or heard a vehicle that sounded like it did with low batteries.
No idea why those codes showed up, but they are gone now. Looks like new battery time but they are the originals.
Thanks for all your help!
Cole076.0
Sep 16, 2019 04:26 AM
JasonWalsh915
Nov 25, 2012 02:55 AM
halfbolt
May 27, 2009 04:59 PM
hunter101
23
Feb 27, 2008 03:44 AM
BritishBartender
Sep 14, 2005 10:24 PM
