changed oil will not start
Old May 27, 2009 | 07:38 AM
halfbolt's Avatar
halfbolt
Question changed oil will not start
I just changed the oil 14l, started up after the oil change to check for leaks. Looked good shut down. Now this morrning will it will not start. Any help would be nice, by the way it turns over great.
Old May 27, 2009 | 08:07 AM
brickie's Avatar
brickie
Have you checked the oil level this morning?
Old May 27, 2009 | 09:48 AM
halfbolt's Avatar
halfbolt
The oil level is fine, I added 14litrs, at time of change. If it helps this not my first time changing the oil. After changing the truck fired back up, ran for 5 min.shut down check for leaks, no leaks. then this morning it rolls over but doesn't fire.
Again THanx Halfbolt
P.S. IF the oil level is down where would it go?
Old May 27, 2009 | 10:00 AM
brickie's Avatar
brickie
14 liters is too much oil by about two liters.If your level is low something fishy is going on. Page 7 Overview: Specifications a couple liters stay in the HPO system.
Old May 27, 2009 | 10:16 AM
ljutic ss's Avatar
ljutic ss
He didn't add too much oil, 14 liter is a little less then 15 quarts.
P.S. my owners manual says 14.2L (15 quarts)
Old May 27, 2009 | 10:33 AM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
1) What brand of oil filter did you use?
2) Did you snap the filter into the cap before screwing the cap down?
3) Is the oil filter cap seated flush with the housing (secure seal)?
3) Did the cap get cracked in some way?
4) What is level of oil on tip-stick?
5) Did you change fuel filters at the same time and this may be a cause (just looking at all options)?
Old May 27, 2009 | 11:52 AM
raptor131's Avatar
raptor131
have you removed the oil filter to make certain nothing is clogged? I really don't believe in coincidences. if it ran fine until then i would say do check everything over that you touched and recheck.
Old May 27, 2009 | 02:29 PM
halfbolt's Avatar
halfbolt
Beach, I use NAPA gold series made by wix, 0-40 XDR esso like allways and the filter and cap comes as one unit, there were no leaks from the filter unit after install,and restart. Would a Overfill situation cause an no start condition? Say 1-2 litres over.
Thanx again Halfbolt
Old May 27, 2009 | 02:59 PM
ljutic ss's Avatar
ljutic ss
Hope you didn't throw away the original oil cap. Stick with the OEM filters, you will be better off.
Old May 27, 2009 | 03:51 PM
UGA33's Avatar
UGA33
Check this video out.
YouTube - Motorcraft Powerstroke Diesel Filter Comparison
Old May 27, 2009 | 04:39 PM
bismic's Avatar
bismic
Using the wrong filter may result in the drain valve in the oil filter housing not being closed. If this happens, the oil can recirculate and possibly not develop the pressure to start up (interlocked at 5 psig on the low pressure oil system and 500 psig on the high pressure oil system).
An overfill situation can be a problem, but not to start-ups.
Old May 27, 2009 | 04:59 PM
halfbolt's Avatar
halfbolt
Update,went to ford dealer, bought new filter and cap. Installed ,still no start cond. ???? Maybe HPOP, I hope not.
Thanx Halfbolt
bio-d
Apr 4, 2009 09:29 AM
1979FordF250
Dec 4, 2007 05:27 AM
someday
Oil & Lubrication
Feb 20, 2006 09:04 AM
bassproguy07
Feb 1, 2006 06:54 PM
bricot
Jan 1, 2003 10:55 AM
