Sponsored by: Real Truck
Brake problems
Old Sep 24, 2020 | 10:38 PM
Ethan Pratt's Avatar
Ethan Pratt
Brake problems
I have a 2000 f350 7.3 and about a month ago I blew a high pressure power steering line so I went to auto zone and got both new high pressure lines and replaced them after replacing my brakes did not work right while driving straight when you hit them they pulse and don’t have the stopping power but if the steering wheel is turned they seem to work normal so I blamed power steering pump for low pressure needless to say I put 3 different pumps on it and also replaced the hydro booster and still the same problem I have no idea what else to try has anyone else has this problem
Old Sep 25, 2020 | 12:41 AM
Bently_Coop's Avatar
Bently_Coop
Did you bleed the Power steering?
Lift the truck off the ground and turn the steering wheel back and forth lock to lock. Otherwise you may need to bleed the brake lines and check the fluid at the calipers.
Old Sep 25, 2020 | 07:55 AM
99powerstrokedF250's Avatar
99powerstrokedF250
If you didn't bleed the system then you're going to have issues. Basically through the process above, and I mean doing it for 5 minutes or so. Don't crank fast, but make sure you hit each lock several times and hold it at lock for a moment each time. Check PS fluid level and fill/repeat until it doesn't go down anymore.
You replaced both high pressure lines (and it sounds like other components as well), you're going to have air in the system, and it doesn't come out quickly with normal driving.
Bleeding the brakes is also a good idea, just to have eliminated that as a potential issue.
Old Sep 25, 2020 | 01:57 PM
Ethan Pratt
I’ve tried bleeding it like that and even cracking the lines but nothing seems to help
Old Oct 13, 2020 | 05:04 PM
MoBill122's Avatar
MoBill122
Papa Smurf
You did use Mercon auto Trans fluid in the power steering ???
Ethan Pratt
38
Oct 4, 2020 12:17 AM
kravenna11
3.0L Powerstroke Diesel
Oct 23, 2018 09:08 AM
redwingsfan
Apr 20, 2006 07:42 PM
RawPower
Feb 1, 2005 07:59 AM
groundcontrol
Apr 7, 2004 09:03 AM
