Hydro-assist steering?
Old Jan 30, 2005 | 08:39 PM
RawPower's Avatar
RawPower
Does anyone know anything about drilling into the C-11 steering box for the high/low pressure lines to creat hydro assist?
Anyone have any detail diagrams of where to drill? (PLC7.3, thanks for those emails, they helped, but now I need a more detailed drawing)
What are the weak spots of a C-11?
Any help, thanks...
Old Jan 31, 2005 | 12:29 AM
PLC7.3's Avatar
PLC7.3
Raw Power checkout the PS pump for Hydra boost system it comes with two pressure lines and one return, may be it can modified to fit your needs.
Old Jan 31, 2005 | 08:37 PM
89ford73's Avatar
89ford73
what does hydro assist mean? i thought all ford diesels had power steering...? or is that not what you are talking about? i have had to drive my ford a couple times with no power steering and it really sucked. i couldn't imaging it all the time. or are you talking about the brake booster?? cuz i hooked up a hydro booster on my truck and it hooked right up, plug-n-play. 30 mins.
Old Jan 31, 2005 | 09:02 PM
RawPower's Avatar
RawPower
Hydro Assist is a system that runs a hydraulic mounted to your axle and tie rod. It has two ports, one for left turns and one for right turns. You drill into the PS gearbox for the Low pressure and High pressure ports (which vary-"Port A" is high pressure when turning right and low pressure when turning left, and "Port B" is opposite of "A"). This set-up still maintains the mechanical linkage between steering box and the tierod in case of failure, but also provides much greater power when turning and little to no stress on the frame around the gearbox mounting points. In order to do this you have to remove the gearbox and strip it completely and then drill two holes in it for the two lines. It acts as a steering stabilizer as well. This set-up is streetlegal, unlike full-hydraulic steering(no pitman arm, tierod, or any mechanical linkage).
Old Jan 31, 2005 | 09:21 PM
89ford73's Avatar
89ford73
ohhhhh! like the guys running 48" swampers? they got a hydraulic cylinder-ram on the front axle. i got ya.
Old Jan 31, 2005 | 09:24 PM
89ford73's Avatar
89ford73
mount a hydraulic pump on the pto and use one of those valve assemblies like on maintainers or something on your steering driveshaft. or like the ones on those center pivot loaders.
Old Feb 1, 2005 | 07:59 AM
RawPower's Avatar
RawPower
Its easier just to drill two holes into the gearbox and run a line from each to opposite sides of the hydraulic. I just need to know where to drill...
rollinblackcloud
Offroad & 4x4
Mar 10, 2014 11:59 PM
Kirbys73F100
Offroad & 4x4
24
Jan 27, 2010 04:42 PM
79F350429
Offroad & 4x4
Mar 6, 2005 07:55 AM
