Engine knocking during acceleration help!!
Old Sep 24, 2020 | 11:48 AM
speter's Avatar
speter
Question Engine knocking during acceleration help!!
Hi There, I recently bought a 1964 F100 with a 292 Y Block. The odometer only reads 23,000 miles and its been refurbished. The stock engine has a double barrel Holley carb on it. It drove well for 5 weeks until this loud knocking began. It occurs when I give it gas and then slowly goes away once I am up to speed. It is loudest in 2nd and literally sounds like someone is hitting the firewall with a hammer. I already replaced the spark plugs but it did not help. I read that this could also be an issue with low octane fuel (which I made the mistake of using 87 recently). Could someone help me??? I'm happy to send a video of the noise as I give it gas. Thank you so much Ford Forum !!!!
Old Sep 24, 2020 | 01:06 PM
chiefdave's Avatar
chiefdave
It could be spark knock if it goes away at cruise. Check your timing setting and set to factory specs. If not pull the oil pan and start looking for something mechanical.
Old Sep 25, 2020 | 01:18 PM
Crop Duster's Avatar
Crop Duster
Those speedometers go to 99,000 then start over no telling how many miles are on it. Anything knocking that loud needs investigated and not driven until you sort it out. Pull the oil filter and cut it open and inspect it for metal. If there is metal in there the type and quantity will tell you where it came from. It sorta sounds like a bearing but who knows until you do some looking around.
Old Sep 25, 2020 | 05:40 PM
john jamieson's Avatar
john jamieson
Maybe a lifter going bad and or weak valve springs.
Old Sep 25, 2020 | 07:22 PM
Tedster9's Avatar
Tedster9
Welcome to FTE
Sorry to hear about the Unpleasantness. Been There, Done That, Got The T Shirt.
Are you familiar with what "spark knock" sounds like, and when or how it occurs?
If it's real bad, it can cause severe engine damage - bust piston ring lands, or holes in the top of pistons. Can WAG a couple things, but I would agree be very careful about driving it until things get checked out.
If it IS spark knock, it means the ignition timing is too far advanced. Did you mess with it?
Without first adjusting the ignition timing this normally can't really happen "out of the blue" unless the internal parts of the distributor have become defective. This is possible on a high mileage distributor. You'll need an ignition timing light, among other tools.
I would suggest a Ford Shop Manual, it has the Tune-Up information in it. There's a few "gotchas" you'll need to learn about too, Y-Blocks are a little bit different than the average V8. On the plus side, they are tough as nails and whatever the problem is, you'll soon have it purring nicely.
Old Sep 25, 2020 | 09:58 PM
Christmas's Avatar
Christmas
Longshot, Check the inside of the distributor cap for condensation.
Old Oct 3, 2020 | 10:57 AM
Tedster9's Avatar
Tedster9
@speter Any luck?
Old Oct 3, 2020 | 11:25 AM
FuzzFace2's Avatar
FuzzFace2
If he is still running points in the 292 he will need to check the point dwell before checking timing.
If the rubbing block has worn down, no grease on the block when installed, it can change the timing.
But you need to find & fix the cause of the noise before damage is done to the motor.
Dave ----
Old Oct 3, 2020 | 01:42 PM
f5fordgirl's Avatar
f5fordgirl
Wondering if you might have an exhaust port almost stopped up, and under hard exceleration the exhaust is going out the carb.
Old Oct 3, 2020 | 01:50 PM
Crop Duster
evilleford
2004 - 2008 F150
Oct 15, 2008 10:35 PM
celticrebel
1978 - 1996 Big Bronco
Mar 17, 2004 12:35 AM
76supercab
Jan 5, 2003 08:57 AM
codegrad
Nov 7, 2002 03:12 PM
lincolnman88
1997 - 2003 F150
Jan 7, 2002 10:13 AM
