Sous or anyone else. Can you make sense of these readings? I tried to use open office, but it doesn't come out right. Is what's happening with EBP and EOT normal?
Just need to select the PID that works for the truck. For EBP, use the EBP_A PID. It will read correctly in Forscan/Forscan Lite. With EOT, there are 2 that are named the same. Pick the second one. Try logging again, and you should see good data from these PIDs.
BWST got you sorted out it seems. We or anyone else that has access to Excel would be more than happy to chart the PID's for you, once the correct PID's have been logged.
BWST pointed out the thread with instructions on how to use the PID Charting Tool. In addition, there are PID's that you should look for specifically. Like EBP_A instead of EBP. Check out that section of the instructions and things should be much clearer for you.
Again, we would be happy to upload a chart for your logged data, we just don't want you chasing ghosts.
