2011 F150 Diagnostic Code Help
Old Sep 16, 2020 | 04:45 PM
Paul Kempf's Avatar
Paul Kempf
Hello all,
Here's the low down:
2011 F150 XLT Extended Cab 4x4
Codes: U0428, C109D, C1282, C1280, C1963
Warnings: (Intermittently) "Service Advance Track", and when accelerating or climbing hills at highway speeds "Check Brake System"
Symptoms: metallic vibration sound from front driver's side
I am looking into the cause(s) for these codes. I am hoping it's 1 thing causing them all, but I am not sure if that's the case and would like to start attacking the most probable causes first. The C109D code says it's "low vacuum"; I have looked for vacuum leaks with no luck. The others I am wondering if they might be caused by an ABS wheel speed sensor and will be testing those tomorrow. I am hoping to do the work myself. Any insights are appreciated.
Thank you,
Paul
Old Sep 16, 2020 | 07:13 PM
steve(ill)'s Avatar
steve(ill)
Traction Control Lamp Flashing/Illuminated – DTCS C1278, C1280, C1282 and/or C1963 – 2009-2012 Ford F-150
TSB 12-11-18
  • TRACTION CONTROL LAMP FLASHING / ILLUMINATED – DTCS C1278, C1280, C1282 AND/OR C1963 – BUILT ON OR BEFORE 6/10/2012
Publication Date: November 29, 2012
FORD FORD
: 2009-2012
F-150 F-150
This article supersedes TSB 12-6-18 to update the vehicle model years, Action statement and add a production fix date.
ISSUE:
Some 2009-2012
F-150 F-150
and 2010-2012
F-150 F-150
Raptor Raptor
vehicles built on or before 6/10/2012 may exhibit a condition where the traction control indicator is flashing or illuminated with diagnostic trouble codes (DTCs) C1278, C1280, C1282, and/or C1963 stored in the anti lock
brake system brake system
ABS ABS
) module. In addition, some customers may complain of intermittent nuisance activation of the
electronic stability control electronic stability control
ESC ESC
) during low speed turning maneuvers while towing a trailer only.
ACTION:
Reprogram the
ABS Module ABS Module
to the latest https://www.motorcraftservice.com/Reprogramming/Calibration using https://www.motorcraftservice.com/diagnostic/diagids release 82.01 and higher. This new https://www.motorcraftservice.com/Reprogramming/Calibration is not included in the VCM 2012.11 DVD. https://www.motorcraftservice.com/Reprogramming/Calibration files may also be obtained at http://www.motorcraft.com/.
Old Sep 16, 2020 | 09:34 PM
Paul Kempf's Avatar
Paul Kempf
Thanks Steve. Is this reprogramming something I can do for free? What causes the noise?
Old Sep 17, 2020 | 01:12 PM
steve(ill)'s Avatar
steve(ill)
Im not sure how you would do it yourself and get access to the software upgrade... Here is the link that gives more details.. Labor rate is 20 minutes work..
https://ford.oemdtc.com/2401/tractio...012-ford-f-150
Old Sep 17, 2020 | 01:34 PM
projectSHO89's Avatar
projectSHO89
Probably ought to fix that mechanical problem first. A software update, while in may be needed later, won't fix whatever is making that noise (which may be the root of the rest of the issues).
Rule #1: Fix the OBVIOUS problems first.
Old Sep 17, 2020 | 03:25 PM
Paul Kempf's Avatar
Paul Kempf
I agree with fixing the mechanical problem first. It doesn't have any symptoms besides the noise, so I'm wondering if maybe it's a heat shield starting to vibrate at a certain RPM... I used Forscan to install a trailer brake to work with my OEM dash LCD. I am wondering if I can do this update with it? I'd imagine it's possible.
oldiron4755
23
Jun 6, 2022 11:35 PM
ALKBENGAL
1997 - 2003 F150
Feb 13, 2013 06:58 PM
afcro
Aerostar
Apr 18, 2004 08:18 PM
Terrafermi_1
Modular V8 (4.6L, 5.4L)
Mar 7, 2004 12:41 AM
