Sponsored by: Auxito
Trouble code help
Old Feb 13, 2013 | 11:46 AM
ALKBENGAL's Avatar
ALKBENGAL
Trouble code help
Hi,
I am new to the forum and i need some help with trouble codes
It is a 2001 f 150 4.2 v6 2wd
here are the codes
p1519
p1000
p1401
p0174
p0173
all taken from a snap on scanner
Any help on where to start would be greatly appreciated.
Thank you
Old Feb 13, 2013 | 12:48 PM
rmccbride's Avatar
rmccbride
Originally Posted by ALKBENGAL
Hi,
here are the codes
p1519
p1000
p1401
p0174
p0173
Thank you
start here? Ford OBD-II Trouble Codes
Have you been working on the truck before these codes showed up? Check that all vacuum hose are OK as a cheap first step..
Old Feb 13, 2013 | 02:08 PM
Bluegrass 7's Avatar
Bluegrass 7
I'm surprised your Snap-On did not give you more help info.
The 173/174 are oppisite code issues. One is saying too Rich, one is saying too Lean. It's possible to have both depending on when the computer saw the fault.
Anyways, it's usually an intake air leak at some point in the intake tract.
The 1401 is an open DPFE sensor circuit. Check the plugup and harness attached to it.
The 1519 is a stuck intake runner control (IMRC) on one or both banks.
They are vacuum operated with sensors for the computer to tell when it's not operating. Shafts operate flow restriction plates inside the runners.
The runners are normally closed down to increase low speed torque then open up as the rpm increases.
The 1000 code is not a trouble code but an indicator that all systems that are normally tested did not pass.
When they all pass testing the 1000 will clear.
I jumped in to help because if you have no idea what to do you could not interpet the codes as there is more to it than just a few discription words.
Good luck.
Old Feb 13, 2013 | 02:18 PM
ALKBENGAL's Avatar
ALKBENGAL
i am going to start working on it this weekend. Thanks for the help so far
is there one code that i should start with that might be more urgent of a matter? The scanner did give more detail however i am at work and i only wrote down the codes so that i could google them.
Old Feb 13, 2013 | 02:37 PM
Bluegrass 7
Seems the 1501 would be the easiest to clear first.
What you need to be awhere of is to decide on what order you will do the work because the codes don't clear instantly.
Such is the case that you don't know if you got a good repair each time unless you clear all codes each time, then run drive cycles to see what comes back.
If you don't do it this way you see old history most of the time and can get confused about where you are with the work.
The computer goes into full diagnostics everytime you clear or reboot.
The EVAP takes the longest so ignor that one.
Hope it make sense.
Good luck.
Old Feb 13, 2013 | 06:58 PM
pdqford's Avatar
pdqford
Not sure what model SnapOn scanner you have, but it should be capable of displaying the Freeze Fram data. The DTC in the FF data is the one that caused the MIL to turn on and will show what else was going on at that time. Many times the first code to trip can cause other codes to pop up.
But you've done the first thing right. (Always right the codes down first! You'd be surprised how many don't and then can't remeber which ones were originally present when they started the repair.)
acm05fsu
1997 - 2003 F150
Dec 26, 2019 02:24 PM
KH85
122
Mar 27, 2013 11:58 PM
B Dobz
Jan 17, 2007 08:52 PM
Whou4
Aug 19, 2004 12:44 AM
Terrafermi_1
Modular V8 (4.6L, 5.4L)
Mar 7, 2004 12:41 AM
