1997 7.3 CEL and codes help please
Old Sep 10, 2020 | 09:58 AM
gg1968's Avatar
gg1968
My 1997 7.3 has a check engine light that has been coming on and then going off intermittently. I had the codes read and there were 4 of them
P1280 (ICP out of range)
P0420 (EPS low)
P0236 (turbo boost sensor A performance)
P0237( turnpvo boost sensor A low circuit)
I have a TS 6 position switch installed, 3” DP. No other mods except a gutted cat. Any info would be appreciated.
Old Sep 10, 2020 | 08:08 PM
oldbird1965's Avatar
oldbird1965
This is in the stickies: https://www.ford-trucks.com/forums/9...ble-codes.html
Old Sep 10, 2020 | 08:36 PM
gg1968's Avatar
gg1968
I know what the code is and what the description is. The “sticky” doesn’t help with this though.
Old Sep 11, 2020 | 04:55 AM
Ad_Brack's Avatar
Ad_Brack
From memory I believe all of these sensors share a common ground for their 5VDC reference. I would start by testing voltage to the ICP, IPR, and any other sensor it is calling out. Check your ground connections.for corrosion.
Sorry I can't provide more detailed info I don't have time to dig through the books but this should be a good start for troubleshooting.
95350PS
21
Jul 2, 2012 09:13 PM
fragglerock
Feb 5, 2011 07:36 PM
badassf250
28
Jan 29, 2011 10:43 PM
dougx75
Aug 16, 2009 07:23 PM
