Add OEM Factory Remote Start with 4 button Key Fob
Old Nov 30, 2024 | 09:18 PM
VintageBikesUSA's Avatar
VintageBikesUSA
2018 STX . I just ordered the following parts and trying to get setup in Forscan. I sure hope this works, its damn cold in TN.
  • 164-R8134 4 Button Key Fob
  • f2gz15607c Tire Pressure Monitoring System Receiver
Old Dec 9, 2024 | 11:07 AM
2012FX4's Avatar
2012FX4
Just want to say thank you so much. Ordered the exact same parts OEM off eBay and now have factory remote start installed on my 2015 F150. My local dealer cut the keys for only $10.
The only hiccup I ran into was that I needed newer version of the OBDII forscan dongle. My old one with the physical MS/HS switch I guess is no longer able to program new key FOBs.
Old Dec 10, 2025 | 10:51 PM
Kyle23u's Avatar
Kyle23u
2nd Gear
Question RTM Vin locked??
Originally Posted by Samizman
I got the new 4 button key and it won’t program for some reason. I got it cut at the dealer and put a new battery in it, any idea as to why it won’t work? I don’t want to skip this step since you say the old keys won’t work
EDIT FIGURED IT OUT, had to use different sequence than what my manual said
Quote:
  • Insert 1st original key and cycle from off to run (not start) eight times (back to back)
  • Turn to off position and remove key
  • Insert 2nd original key and cycle from off to run two times back to back
    • Dash displayed my SecuriCode keypad door code
  • Insert new key and cycle from off to run leave in until dash displays Key Programmed
  • Key Programmed might not display but you should hear the door locks actuate.
  • Remove key and check that the unlock /lock buttons work. Then try the remote start button. If it all works you're good to go
Hello, I did the same thing but i couldnt get the remote keyless entry to work on the 4 button 902hz fob. but i can get it to start the truck in the ignition. I have replaced the RTM with a F2GT-15K619-CB from a different vehicle and i couldnt get key to unlock or lock or such, not responsive at all. Factory keys are the 3 button 315hz.
I have used chatgpt to try get it figure out but it is very good at being confidentially wrong lol. I check its work with the Forscan 2015-2020 F150s - Livinitup google sheet and changed to allow remote start and to try get RTM to work or see if the BCM needs programed to accept 902hz fobs now from 315hz but no luck? (this could also be a cheap clone thats not actaully 902hz key that wireless entry dont work??
Amazon Amazon
It now wants me to Run PATS to wipe and reprogram keys as it will program the RTM with the porper VIN to communicate possibly??? but i am not sure if i should try that or not? As i do get the keys to show the keypad code and can program new key and does the hazard light flash and door actuates afterwards but still no luck on the remote. Thank you
2017 F150 XLT 2.7L 4x4 301A
Last edited by Kyle23u; Dec 10, 2025 at 10:55 PM. Reason: Adding 902hz keyfob link i have
Old Mar 19, 2026 | 05:32 AM
Bronson Sherrill's Avatar
Bronson Sherrill
4th Gear
Originally Posted by mobil1
Excellent Post
I just added this to my 2017 F350 XLT works great
Thank you very much
Did you use the dual frequency or single frequency RTM module?
Trying to do this on my 2016 F150 XLT
Old Mar 19, 2026 | 05:33 AM
Bronson Sherrill
4th Gear
Did this work for you? I beleive that RTM is a single 902mhz module correct? We dont need the dual frequency module?
Old Mar 23, 2026 | 10:11 AM
Bronson Sherrill
4th Gear
Which dongle did you order?? Do you have FB or can you text me. ive got some questions. please & thank you. 863-528-2532
LucasMN
1997 - 2003 F150
Oct 12, 2012 10:36 AM
BillyBob69
1997 - 2003 F150
Jul 20, 2005 02:33 PM
GSPope
Jan 17, 2005 08:35 PM
Wendell
Electrical Systems/Wiring
Oct 15, 2003 05:03 PM
iflooru
Nov 20, 2002 05:12 PM
