Installed a rebuilt transmission from ford in my 2004 f 350 and when pulling my camper in tow/haul mode down hill it downshifts into low gear and acts like the drivetrain is coming out from my truck. Only does this when pulling a load and in tow/haul mode going downhill. Acts likes it’s shifting into low too soon. My question is how or if you can adjust when it downshifts?
I don't have a new trans in the truck (60000mls stock), but here it's the same.
The transmission shifts to a low gear very early and the engine "sings" in high notes.
I had already thought about retrofitting an engine brake
Sounds like tow/haul is working as designed. If more braking is needed why not simply adjust the programming rather than adding a separate engine brake that was not part of the system design? my .02, Russ
I know it’s suppose to downshift going downhill but when it shifts into low gear it sounds like all the gears are grinding and coming out from under the truck. It is like it’s downshifting too soon.
my 05 does the same thing, I just take it out of tow haul going down a step hill,
Yep. You have to keep a light foot on the brake to keep the Tow/Haul mode from freaking out, thinking you are barreling out of control down a mountain. I find it helps a whole lot if you slow down a lot prior to the descent..
that's how I do it too. If I ride slowly in 5th gear and push T/H, the trans shift to 3rd gear. Then i drive for example downhill serpentines, the engine revs up and slow down the truck(by the way, you can hear how the clattering of the injectors stops when truck drive downhill). if i now slow down, brake and drive a curve, he shifts me into 2nd gear. But it don't "bang" anything if the thread creator means something like that.
