Odd Tow/Haul shift behavior
Old Feb 8, 2019 | 08:03 AM
Midnightmoon's Avatar
Midnightmoon
Has anyone experienced any odd or harsh downshifts while in tow haul mode? Truck in question is a 2018 3.5L Ecoboost Max tow. Usually, my truck will downshift to 3rd and hold that gear on a long grade while towing and in tow/haul mode. However, I've noticed twice now that if I slow the truck down below 25 mph, it will attempt to shift to 2nd. That's when the fun begins. It feels as if the truck completely releases the transmission for a moment and then slams in to 2nd violently.
I tow quite a bit with this truck and it has only happened twice, but it definitely gets your attention when it does.
Anyone have any insight in to this issue?
Old Feb 8, 2019 | 11:37 AM
storage_man's Avatar
storage_man
The correct term is "Programmed Aggressiveness". This is my second Ford with tow/haul transmission capability and it indeed becomes very aggressive holding a gear when a climbing hill and the same thing on down hill where it will go into the lowest gear possible (without over reving the engine or blowing it up) and hold that gear for a extended period of time. On the up hill its really trying to keep the engine with in its power/torque range, on the down hill its trying to maximize the engine breaking capability. Also the slamming of gears when up/down shifting is common. I talked to a Ford Diesel tech about it years ago, his comment was its better than ruining your engine via overheating or detonation. After that I really didn't care.
In my current F150, the aggressiveness of the transmission in Tow/Haul doesn't bother me as much, but when I had the F250 Diesel, I always felt that the engine was going to blow up ! If you ever did any towing with a manual transmission, you would be doing much of the same thing (although not as aggressive).
Old Feb 8, 2019 | 03:47 PM
Midnightmoon
Thank you for the reply. It's good to know that this isn't abnormal operation.
Old Feb 8, 2019 | 04:03 PM
jimmy-six's Avatar
jimmy-six
Have you tried "sport mode" when towing. I found with my 18-5.0 I acted better on down hill with #9000 tagging behind. I hope I'm not wearing to out but I use the the up/down switch a lot when ever towing.
Old Feb 8, 2019 | 04:06 PM
Midnightmoon
I have not tried Sport Mode, but I will the next time out. I tow on the same road somewhat regularly, so it will be easy to compare how each mode behaves on that stretch of road.
Old Feb 8, 2019 | 05:33 PM
GlueGuy's Avatar
GlueGuy
If I'm in difficult terrain and towing a load, I will use the +/- on the shifter to encourage the tranny to downshift if I think it needs it. If it is particularly difficult (like a lot of up & down), I might even shift to "M", and do the shifting myself.
Old Feb 9, 2019 | 08:49 AM
onug's Avatar
onug
The 3rd-2nd gear transition is notorious on these trucks for being harsh. It can be a “strong” shift in the morning going 2-3 when the fluid is cold and dropping down is even worse.
Old Feb 9, 2019 | 08:57 PM
Midnightmoon
Thank you again for confirming what I am feeling is not out of the ordinary. It certainly surprised me when it happened the first time.
Old Feb 10, 2019 | 12:08 AM
onug's Avatar
onug
No problem...it gets brought up here occasionally. Ford does a great job of “Marketing” how well they test their trucks on the road, and I’m still surprised this wasn’t fixed. There’s no way the engineers didn’t feel the harsh 2-3 shifting when testing. It’s too consistent.
Old Feb 11, 2019 | 01:35 PM
jimmy-six's Avatar
jimmy-six
Whether having the trailer behind or not, I pay no attention to how the 10sp in my '18 shifts until it's warm. If I think about it pulling away from in front of the house in the mornings I'll put it in "sport mode" which uses all the gears in a line then go back to normal after a while.
Personally I think a lot of the trans complaints are coming when the the trans is not warmed up completely...If it's legit with these new ones it can be programed out. Yes it's a pain to remember thing we should do especially on a 40-50-60-70 thousand dollar truck but first and foremost....it's goddamned truck not a Lincoln towncar....
Old Feb 12, 2019 | 12:46 PM
TJReams's Avatar
TJReams
Amen jimmy-six amen!
Old Feb 12, 2019 | 01:20 PM
CR172's Avatar
CR172
If I'm forking out 50 - 60 thousand for a "goddamned truck" it better shift without problems. With all the money and time that went to R&D on that tranny there is no excuse for the problems I am reading about. And the same goes for the "goddamned" door locks. No excuse.
Old Feb 12, 2019 | 08:27 PM
jimmy-six's Avatar
jimmy-six
If every one was so displeased with these F-150's it would not be the best selling truck at any cost and they would not sell.
Old Feb 14, 2019 | 07:34 AM
smokewagun's Avatar
smokewagun
I AGREE! Mine “clunks” into gears and sounds like a mechanical shifter is forced into gear. Whether it be this $56k truck or a $72k King Ranch, it better be smooth. If I wanted a POS transmission, I’d have bought a 1983 Dodge. What frosts my donkey is it is so erratic. I don’t dare use other modes, or it’s like the truck has to relearn how to shift, and it can’t. Why so many modes? How can a transmission effectively learn your habits with each, and switch in a penta-polar moment between the five modes? Simple. It can’t, and never will.
Old Feb 14, 2019 | 12:11 PM
jimmy-six's Avatar
jimmy-six
I didn't mean to throw a monkey wrench in the discussion of the 10 speed transmissions. There have been over 1,000,000 F-150 made with the introduction of it in 2017 and into 2019. and all of them are not back at the Ford dealerships waiting for some repair/revision. Maybe I'm more tolerant I don't know. I do know that my 96, 04, and 13 never had a problem but also had half the gears.
This 18 is different and I didn't think about skipping gears and all when I bought it. Mine has never banged/clunked or what ever into a gear but as I have stated it is a different trans when cold that when it's warm Normal? I don't know but like pushing the auto start button I've learned to work around it.
First and foremost I'm a gear head. Things like this do not bother me. To give you an idea in the 8 years I owned my 96 351 F-150 it had 4 transmission services with filters, I towed a lot with it. The 04 got 5 and it was a diesel. The 13 got one at 30,000 miles and the dealership overfilled it by 1-1/2 qts and will never touch another one. If putting it in "sport mode or tow/haul" will save it when it's cold I'm going to do it. It's a button and ez to do until I'm waiting at a signal in 3-5 miles. Should we do it? Hell I don't know. They say the trans is just learning how we drive. I drive with a very very light foot and that's why mine does what it does I guess. Maybe we should go on the Corvette page and see what's happening to them because it's the same trans. Sorry if I offended anyone. I spent $50K too and want it right.
