Missing when not warmed up?
Old Aug 29, 2020 | 03:31 PM
bparker191's Avatar
bparker191
Truck misses when not warmed up. Stops when EOT hits 180 degrees. Runs rough and contstantly misses.....2003 f250 6.0. HELP!!!!!
Old Aug 29, 2020 | 03:38 PM
npccpartsman's Avatar
npccpartsman
Welcome to FTE!!!
I suspect it's your injectors and you might want to search the term stiction. Really though you need to get your truck scanned for codes. If you have a windows computer you can get a program called Forscan and with an ELM adapter that plugs into the OBDII diagnostic port of your truck you can scan your truck's computer. How many miles on your truck?
Old Aug 29, 2020 | 04:11 PM
bparker191's Avatar
bparker191
Help.
Scan gauge 2 shows no codes. Truck has 136k.
Old Aug 29, 2020 | 06:04 PM
Tileguy66062's Avatar
Tileguy66062
Mine used to do the same thing. I add Rev X from Amazon each oil change. Two 4 oz bottles. After the first time you may only need to use one bottle. Completely stopped the stiction and missing.
Old Aug 29, 2020 | 08:14 PM
bismic's Avatar
bismic
Scangauge is a rather poor code reader.
Old Aug 29, 2020 | 08:17 PM
xcrsp440's Avatar
xcrsp440
Scan gauge is adequate at reading sensors. But it is not the best at finding DTCs. The inexpensive Forscan app and an obd2 adapter does wonders and is very affordable.
Old Aug 29, 2020 | 08:42 PM
bparker191's Avatar
bparker191
thank you. I will look into that. Scan gauge came with the pickup. It is my first diesel. Trying to learn as I go.
Old Aug 30, 2020 | 09:51 AM
IHateCommieCars's Avatar
IHateCommieCars
The difference between cold and hot is the viscosity of the oil. That points to the injectors not moving oil cleanly. What oil are you using? You could try 5w and see if that helps. If using the injector cleaners and thinning the oil doesn't clear it up, you may have a weak injector. The inexpensive apps (Forscan, Torque, the SG device) don't do a cylinder contrib test that helps identify which injector is bad. I've had some nice folks around the country help me a few times on the road with a free, quick scan by their pro-level tools (SnapOn, Ford IDS, AutoEnginuity, etc). Some others have charged me as much as $80 to do it. There are also some mechanical methods for identifying the weak injector.
I'd also take this occasion to warn you as a new diesel guy - make sure you have good fuel pressure at all times. Low pressure burns up injectors. Replace the injectors and they burn up again. Don't ask me how I and dozens of others here know that. I've not heard of low pressure causing a miss that clears up once warm, so hopefully you're OK, but it can cause a miss - after it's burned up an injector.
droffan
May 5, 2010 11:44 AM
Brandon06250
Jan 10, 2008 08:35 PM
bennie
Jul 26, 2007 11:32 AM
ksigforlife
Nov 21, 2005 02:17 PM
4AVIEW
Electrical Systems/Wiring
Jun 1, 2003 10:58 PM
