DB2 Injection Pump Inquiry
Old Aug 11, 2020 | 09:37 AM
FordMasterRace's Avatar
FordMasterRace
In front of throttle cable on top of IP
What is that rod with the broken seal? It appears to be not functioning properly because it just slides down and does not stay up. Thanks
Old Aug 11, 2020 | 11:41 AM
Charmalu's Avatar
Charmalu
That`s the fast idle solenoid that speeds the engine up when it is cold
for faster warm ups. Gets to a certain temp and it cuts out and the
engine goes to an idle.
Charlie
Old Aug 11, 2020 | 11:59 AM
FordMasterRace
Charlie
Okay, cool, thank you! So is it functioning as it should? With the truck off and upon start up it just sits at the lowest point.
Old Aug 11, 2020 | 12:50 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
if the engine is above like 112F then it will not engage ... you can Test it by applying 12 volts to it.
Old Aug 11, 2020 | 08:04 PM
tecgod13's Avatar
tecgod13
Note that the solenoid may not be strong enough to move the throttle lever by itself. It will however hold the throttle up if the pedal is tapped before starting (hence why the manual states to press the accelerator pedal before cranking).
It can be adjust by turning the rod to lengthen or shorten how far it sticks out when energized.
Old Aug 11, 2020 | 08:45 PM
FordMasterRace
Is this advisable? I live in Southern California and I purchased and drove this truck from Truckee, Ca to my home. Truckee is far up north by Lake Tahoe. So my question is, should I mess with this rod?
Old Aug 11, 2020 | 09:00 PM
Chevy_Eater's Avatar
Chevy_Eater
Does your fast idle work like it should? If so let it be.
Like TG says, the solenoid isn't designed to lift the throttle, it just holds it in place. That's why when you first start the truck you turn the key "on", depress and release the throttle, then start the engine. It will keep your truck at high idle until it reaches temp then it kicks down.
It's an incredibly simple system and most likely works as long as the solenoid and the temp sensor are plugged in.
Old Aug 12, 2020 | 08:44 AM
tjc transport's Avatar
tjc transport
i ain't rite
mine has not worked in over 300,000 miles. and i have no issues even below zero. once the engine starts, it just idles a little lower when cold.
Old Aug 12, 2020 | 09:21 AM
FordMasterRace
I’m not sure mine works then. I lifted it up to the throttle plate with the truck off. Then attempted to start it and it fell back down. Truck is cold. Hmm
Old Aug 12, 2020 | 11:32 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
And like TJC says too, I doubt you need it in Southern CA.
anyway you have the schematic so some simple checks with a meter will tell you what is happening.
Old Aug 12, 2020 | 02:01 PM
Chevy_Eater
Check to see if it has 12v at it when the engine's cold, key on.
Old Aug 12, 2020 | 07:52 PM
FordMasterRace
Ok. Thanks a lot guys.
AnotherChef
Mar 18, 2020 01:43 AM
bashby
May 14, 2015 02:12 PM
rlebar
17
Sep 10, 2014 07:55 PM
Ford_Six
Jan 18, 2012 08:33 PM
aussieswimmer18
Nov 25, 2010 06:10 AM
