Did my injection pump die?
Old May 12, 2015 | 12:46 PM
bashby's Avatar
bashby
I pushed in the clutch in to come to a stop and the engine revved up to about 1800 rpm. I hit the throttle a couple times thinking the cable was stuck. It felt weird, like the cable was binding. Then the pedal kinda popped and the engine shut off. I checked the cable and it is intact and functioning. FSS clicks when disconnected. Cranks fast, no smoke from the tailpipe. My Facet E pump is pushing plenty of fuel to the injection pump.
AFAIK, about all it can be is the injection pump. Any other suggestions?
Old May 12, 2015 | 01:30 PM
tecgod13's Avatar
tecgod13
Sticky metering valve?
Crack an injector line and see if anything comes out when cranking.
Old May 12, 2015 | 04:51 PM
bashby's Avatar
bashby
I'm not near the truck right now so I can't try that. I have a parts engine that I took the pump off of and I will swap them out tomorrow. Any more input on the matter would be appreciated.
Old May 12, 2015 | 05:24 PM
madpogue's Avatar
madpogue
I wouldn't go snatching the pump without some initial diagnosis, unless you're looking forward to the adventure of timing it. Given the sequence of events, I can't help but wonder if the arm that the accelerator cable engages might have somehow come loose from the shaft it turns on the pump. Yeah, you confirmed the cable is alright, and presumably it's pulling the armature. But is it actually rotating the shaft (sorry, I'm not sure exactly what that shaft is called)?
Old May 12, 2015 | 05:34 PM
bashby's Avatar
bashby
It is. This shaft goes all the way through the pump and is rotating on the side where
the TPS. mounts. ( I know Ford doesn't call it a TPS. but almost every bOdy else does. .. why
does FOrd have to be different? )
Old May 13, 2015 | 06:28 AM
tjc transport's Avatar
tjc transport
i ain't rite
i would have to agree with your diagnosis that something in the pump broke.
Old May 14, 2015 | 11:08 AM
RacinNdrummin's Avatar
RacinNdrummin
Sounds like maybe something in the governor assembly came apart and bound up causing the input shaft to shear....Maybe a flyweight came out or something... Either way, it was a freak incident, not common for sure...
No weird noises or vibrations before it shut off?
Old May 14, 2015 | 11:16 AM
bashby's Avatar
bashby
It was the pump. I swapped it with one off an old motor and its running again. The old one feels like the input shaft sheared. Would it still be a good core if tbe used one I put on is as worn out as I think it is?
Old May 14, 2015 | 11:39 AM
RacinNdrummin
Depends on what caused the input to shear. If its hydraulic head related, it renders the core nearly useless, if it tore up a bunch of governor related parts, or the housing, same deal, but if something just got wedged in a freak accident, and nothing is severely damaged but the input shaft, it can be a good core.
Old May 14, 2015 | 12:14 PM
bashby's Avatar
bashby
The truck seems to run pretty good. I dont have a timing meter. I just left the lines attached when I pulled it off the old engine. When the old engine was in my truck it smoked really bad when it was cold out. I can't remember how it was in warm weather but it had a bad exhaust valve and I figured the pump was on its last leg with all the smoke... fingers are crossed. If I need a pump I was going to go with one from RandD. I'm not sure if the smallest one you sell would be good for a N.A. truck though. If I do turbo it down the road it would probably be a used banks or factory.... whatever I can find cheap.
Old May 14, 2015 | 01:22 PM
RacinNdrummin
That calibration I did for the bronco is really nice for N/A, I am thinking about putting it up on the site as an HO N/A pump... The RPM range alone is worth it.
Old May 14, 2015 | 01:47 PM
bashby's Avatar
bashby
I bet you'd sell a lot of them.
Old May 14, 2015 | 02:12 PM
SnuffthePunkz's Avatar
SnuffthePunkz
I would love a HO N/A pump. My truck is being built as more of a wheeler/bush truck and as much as I would love a turbo for a little extra oomph, it just screams more to break 6 hours from pavement...
If he did, he'd have at least one up here.
aussieswimmer18
Nov 25, 2010 06:10 AM
axel 56
Sep 23, 2008 08:47 PM
zero 2
Nov 4, 2006 06:02 AM
Tommy C
Feb 24, 2005 09:43 PM
q5ka
Oct 18, 2004 08:22 PM
