altornator help
Old Oct 20, 2003 | 12:57 PM
bcf's Avatar
bcf
Question altornator help
I replaced my alternator a few months ago. Everything is fine, I just have a few questions. I'm going to be plowing this winter, and want to upgrade my charging system. Is it possible to get a rebuild kit for my old alternator, bringing it from 80 amp to 110 or 130? Or should I just get a Ford 3G 130 alternator? Could I possibly overchange my system, possibly causing damage?
Old Oct 20, 2003 | 01:38 PM
macguyver's Avatar
macguyver
I'm not sure on the fit, but a higher amp alternator will only supply the higher amperage when needed. The regulator will still limit the voltage to the same levels.
Old Oct 20, 2003 | 01:43 PM
leov5's Avatar
leov5
hey bcf, about 3 months ago a changed the 60 amp to 100 amp alt. with non problems. didnt even have to change the belt size. i went to pick a part and found an alt from a lincoln towncar that had the oversize alt. and changed the pulley on the front to v-belt type. everything else just bolts up. you can check a previous post under my name leov5 and read it in more detail.
good luck
leo
Old Oct 20, 2003 | 05:39 PM
Franklin2's Avatar
Franklin2
Here's leov5's old post. Looks like you could call out the model year car and get a new alt at the store if you wanted.
https://www.ford-trucks.com/forums/s...hreadid=133692
Old Oct 20, 2003 | 07:28 PM
bcf's Avatar
bcf
thanx guys
funzjb1
Nov 9, 2013 08:29 AM
ac700wildcat
39
Dec 16, 2010 02:48 AM
Big-old-460
42
Nov 7, 2010 12:04 AM
03BLKEB
May 6, 2009 02:05 PM
august676
Jul 14, 2003 10:58 AM
