Ok need a better ALTERNATOR ?!?
OK so the 85 watt stock alternator just will not cut it, with my rebuild ..
i would like something over 110 more like 130 amps would be great..
I am installing 2 Kc lights 40 amp and a 12 v Pa system in my truck..
i would like to spend under 200 on the re-manufactured one if possible
I need links to sites and advice thx ..
i have been looking around with 0 luck
thxs F.T.E
jayson
Also What other types of alternators could fit on my truck ?
I found a 7.3 diesel one for 96 bucks that 130 amp ! could t hat work ?
New engine rebuild pics soon waiting on Parts possibly Monday
thxs F.T.E
jayson
thxs F.T.E
jayson
thxs F.T.E
jayson
Ok how do i know
Pick the mounting style and clocking that best suits your vehicle??
I am not to sure how to chose the right One for my set up ? any advice ?
Ford f-350 1993 / 1979 block and a 1993 top end.
I just did a 3G swap on my 89 f250 351. I got everything i needed at the junk yard. I got the alternator off of a late 90's early 2000's Ford taurus. I took as much of the charging cable i could off of that car and found a car with a fusable link charging cable and spliced the two together i got the plug too off of the taurus. The only problem with using this alternator is that it is not clocked right for our trucks. The plug and charging cable can't be disconnected until the alternator is unbolted but it works and it kind of makes it look a little neater that way. The new bolts at the hardware stor the 2g butt connector got from hardware store. Spent about $30 on everything
Call RJM w/ your specs & load demand. Your Alt. choice should be slightly above that.
These guy's are local: Wayne Electric Home Page
Ask for the owner & tell him "Mike Jablonski" from the LBPD Motor Patrol Association sent you. He's also a member. Installation is very reasonable.
Ryan has a great writeup about the 3G alternator in this thread: FullSizeBronco.com 3G alternator FACTS
Depends on the size & there's definitely a wiring mod going to a 3G.
hey boss I wanted to tell you thank you .. you saved me a ton of money Steve will wire it in my truck for me for an amazing price , Thxs mate. I owe you a coffee .
i only have one more Question, what alternator do i buy, as in I want 130 amps or more ... just not sure on the Pivot angle etc , any advice ?
Jayson ,
cali, cypress
Jayson ,
cali, cypress
Jayson ,
cali, cypress
OK np i am going to go with a 160 amp sounds bout right , if you ever have a question bout your engine / wiring stuff let me know , i could totally help.
thxs again mate , Repp point added thxs again
jayson
jayson
Thanks! I'll keep that in mind. Your the closest member in proximity I know.
I dont know what diesel alt you are talking about but a powerstroke one from any year will not work. And by the looks of it my 86 6.9 diesel alt will not work either
